Re: 440 trucks
[Re: adventurer]
#5213
02/27/05 12:50 PM
02/27/05 12:50 PM
Posts: 7,512 Lebanon ,PA in the Susquehanna...
70Challengerse
should have my motor back by next weekend oh boy,,,oh boy,,,I cant wait
That's great . So what all did your machine shop end up doing to your engine?
Joe where are you?
Re: 440 trucks
[Re: 70Challengerse]
#5214
02/27/05 02:20 PM
02/27/05 02:20 PM
Posts: 390 Hawaii
smokn440
super street
super street
Hawaii
In Hawaii just having a super busy weekend,,,going 30 over on the bore,,,new pistons,,rings,,cam,,oil pump,,,the usual bottom end rebuild,,,,freshened up heads,,,valve job,,,and I had em put it all back together,,,I just have to put water pump and intake on,,,,so now i gotta get out there and clean up water pump today,,,,lucky for me its pourin rain and saved me from yard work today
Re: 440 trucks
#5217
02/28/05 03:03 PM
02/28/05 03:03 PM
I think you should give flying a try, If you like speed it is a rush on takeoff.
Re: 440 trucks
[Re: smokn440]
#5218
03/01/05 12:29 AM
03/01/05 12:29 AM
Posts: 1,093 It's beer:30 somewhere
adventurer
So what did you end up choosing on cams? A few tips on the new engine that you may or maynot know to do, be sure you prime the engines oil system before ever firing it up. Get all those oil galley full of oil. Dry start is one of the most common new engine failures. Also don't add any of those oil additives they can keep your new rings from seating. I know you have your engine bay all ready so you won't be doing this but don't leave a freshly built engine setting for too long before starting. A month or so won't hurt but if its going to be longer be sure you turn the engine over periodicly by hand to keep everything free. Also another startup problem is having the coolant system not completly bleed of air before firing. If there is trapped air in the radiator system the engine temp will got out the roof real quick. That happen to me when I first fired my engine up. And one last thing and I'll quit preaching be sure to follow breakin procedures on your camshaft after the engine is fired up. Most hyd. cams need to be "run in" when first fired up. You do this by getting the engine running first, make sure you have no major leaks and then run the engine at 1500/2000 rpm for about 15/20 minutes. This hardens the cam & lifters to one another. Your machine shop will probably tell you all this but just in case. Good Luck with the new engine
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
