Re: valve to piston
[Re: Ian]
#520487
11/10/09 12:51 PM
11/10/09 12:51 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Why would anyone want to switch to a roller with the same spec's? I would just keep the flat tappet in that case. Its hard to compare a flat tappet cam to a roller even if the spec's are close..They are totally diff. I always check V-P specs, and degree the cam each and every time one is installed no exceptions period.
But to answer your direct question relatively speaking "Yes".
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
