and what can I expect? 1st off this is going into my '68 Coronet 727 3:91 rear. Street only, maybe a 1/4 mile blast for fun. I want reliabilty and not tuning everytime I want to take it out.
440 / with all nessesary machine work/Balanced.
Ross 99539 .030 2.065 CH
New Scat Rods
Block decked to 10.700 with a .039 gasket and I hope a .040 quench. Sound right??
440 source stealth heads
Full grooved mains w HV pump
Lunati 60303 or 60304...
Was planning to use MP 1.5 stock rocker system
Holley Street Dominator intake
Holley 750 or 850 DP
1 7/8 headers 3 inch pipe with a x pipe
MP or MSD ignition...
I also need a some torque convertor advice.
Will my compr. be 10:1 or close and what kinda HP will this combo make??
I know this alot of questions but this is my 1st build and been doing alot of reading and asking questions and from what I have gathered I put this together. I did post this on the
Q@A but want to look to you racers and get your take an
Will this have good street manners and run on pump gas. Don't mind a nice lope and will be running manual brakes so that will not be a issue.
Thnx for reading and look forward to hearing other opinions. If i forgot anything LMK and I will answer ASAP!!
THNX!!!!!
