Challenger/Cuda door panel material?
#519945
11/08/09 08:36 PM
11/08/09 08:36 PM
Posts: 654 MN
astrobuf
MN
I'm in the process of attempting to repair some interiaor door panels with have cracks and broken bits in the screw flange area. An initial attempt to "glue" the pieces back together with an epoxy theoretically for use with "slippery" plastics such as ABS has failed. Instead, I'm now using a "Plastic Welder" (scored at Harbor Freight) and initial results look very good. Trouble is, I thought the panels were ABS, but the ABS filler rod I have melts at a much higher temp than the door panels and seems incompatible. What are these panels made of and what works best as a filler material? Are there other methods to effect this repair that work better? Thx Astrobuf
So, are you really a Rocket Scientist?
Re: Challenger/Cuda door panel material?
[Re: ScottSmith_Harms]
#519948
11/08/09 10:26 PM
11/08/09 10:26 PM
Posts: 654 MN
astrobuf
MN
Scott,
Polypropylene is not the same as Polyethelyne. HDPE and LDPE are high and low density polyethylene. I'm not sure if they'd be compatible with polypropylene. PP is a chain of 3 carbon monomers, PE is a chain of 2 carbon monomers.
All the above technical info is about what I remember form HS Chemistry of 30 years ago! It may not matter if they are different? Have you done this kind of repair on these panels? Is there a better way to do this?
Astrobuf
[Re: astrobuf]
#519949
11/08/09 10:42 PM
11/08/09 10:42 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Scott is the resident Mad Scientist when dealing with plastic...
And Bugs, can't forget about bugs.........
#519951
11/10/09 12:18 AM
11/10/09 12:18 AM
Posts: 654 MN
astrobuf
MN
Scott,
Thanks for the confirmation that I can use a PP rod on PE. I'm a Mech Engineer in my spare time, and work for a large specialty materials company surrounded by Chem Engr's. My buddies know everything about these materials when run through an extruder, but nothing about fixing them on a car!
My calibrated fingers think the panels are PP. PE, especially LDPE is much softer and sliperier than the panels. I vaguely recall there is a test one can run, burning a small sample of the material, the smoke generated is different between PE and PP, I just don't recall how. I'll let you know what I figure out.
Meanwhile, I bought a scrap panel on Ebag to have some matching stock to work with!
Astrobuf
[Re: astrobuf]
#519952
11/10/09 12:25 AM
11/10/09 12:25 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes you can do a burn test to determine the basic plastic family, but it's not going to nail down specific blends (and most of the THOUSANDS of materials out there are blends) PE and PP are bit difficult to distinguish in a home brewed burn test, a plastics lab spectragraph test can nail it down but that requires.... Well, a lab Feel like playing around with it here's a site that can help you: Burn Test*And yes, I agree, door panels are most likely PP
