Re: pete from best machine
[Re: PETE@BESTMACHINE]
#518478
11/10/09 10:45 AM
11/10/09 10:45 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Thanks for all the concern its means a lot. Some of you I have met and know and others just on here and it really does help. I was trying to get the chassis sorted out with the help of Keith the owner of Skinny Kid Race Cars, who has fixed a lot of stuff on the car. We installed a Race-Pak data system to get the converter figured out and the best shift point. Well the converter is to tight only goes to appox 6000 and lugs the engine down on the launch for almost a second then go up to the shift point. It still had a few 1.13 sixty fts at 2570LBS with a glide. It got loose at the 330 Ft mark and went left hard and hit the wall. I am still sore but getting better. Thanks again.
Sorry to hear of your misfortune, Pete.
Get well soon
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
