Which rear main seal kit to get? 440 #518337
11/07/09 04:14 PM
11/07/09 04:14 PM
Hawaii
Dodgeballs Offline OP
Hawaii
The first is O'reilly pt# BS40240. No brand listed.
The second is O'reilly pt# 1968. Mr Gasket.
I've never changed the rear main on a 440 before.
Re: Which rear main seal kit to get? 440 [Re: Dodgeballs] #518338
11/07/09 04:15 PM
11/07/09 04:15 PM
Hawaii
Hawaii
Mr Gasket set
Re: Which rear main seal kit to get? 440 [Re: Dodgeballs] #518339
11/07/09 05:09 PM
11/07/09 05:09 PM
The Mr gasket set has the side vertical seals and the 2 half moon neoprene seals and the other kit has those plus the (2) L shaped pieces that are used on a /6 (the kit fits both engines) which are not used on a BB. Not sure on the other extra pieces.
Re: Which rear main seal kit to get? 440 [Re: RapidRobert] #518340
11/07/09 05:34 PM
11/07/09 05:34 PM
I used the mopar kit from Summit
Re: Which rear main seal kit to get? 440 [Re: Dodgeballs] #518341
11/07/09 05:45 PM
11/07/09 05:45 PM
Hawaii
Hawaii
thanks. Wasn't sure what the extra pieces were.
Re: Which rear main seal kit to get? 440 [Re: RapidRobert] #518342
11/08/09 08:14 AM
11/08/09 08:14 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
...the (2) L shaped pieces that are used on a /6 (the kit fits both engines) which are not used on a BB.
Always wondered what they were for...
