Re: 66 Coronet + 30x 9 slicks=He!!
[Re: 2FASTCORONET]
#516546
11/05/09 11:54 AM
11/05/09 11:54 AM
Posts: 535 Ohio
racerAL
Ohio
what width wheel are you trying to run? i have ran 30x9 on my car, running 29x9 now,i needed to trim the inner lip to make room..goin forward or back a 1/2 inch with your wheel base isn't gonna make it rub more..imo...i tried an 8 inch wheel and it was a no go without ALOT of trimming..it looked to me like i would have to trim the inner lip flush with the quarter panel to make a 8 inch wheel work...so being reluctant to do that much trimming(or spend BIG $ and buy wheels with a diff back space) i ended up with a 7 inch wheel..still a tight fit and a pain to get on and off the car, but they dont rub.. ..
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: 2FASTCORONET]
#516551
11/05/09 02:37 PM
11/05/09 02:37 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
With an 8" wide wheel you're going to need about 5 1/8 maybe 5 1/4 backspace without doing a bunch the the wheel wells.
I tried a 15x8 wheel at McCormacks and it was 5 1/2 BS which was to much, we added spacers and came up with the 5 1/8 number (I was going to order a custom wheel)
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: 2FASTCORONET]
#516555
11/05/09 03:41 PM
11/05/09 03:41 PM
Sledge_57
Dearborn Hts, MI
I assume you mean 8.5 wide with 5.75 BS which would be right according to what we figured out. What's your plan for the Centerlines?
Doug
