anyone run a 8" converter in a high HP car
#514687
11/02/09 09:56 PM
11/02/09 09:56 PM
does anyone run a 8" converter in a torqueflite with over 1200+ hp at the flywheel, 1185 HP at the rear wheels. if not what do you run? will i go through the converter? this is a N/A motor, no power adders. i tried a 9.5 but not too thrilled with the performance.
Re: anyone run a 8" converter in a high HP car
[Re: Cab_Burge]
#514690
11/02/09 11:07 PM
11/02/09 11:07 PM
i am running a cable 63 pushbutton 727 trans.
#514691
11/02/09 11:19 PM
11/02/09 11:19 PM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
An 8 inch core doesn't have the diameter needed to hold that much torque and lock up. At least a tight 9 inch ,maybe 9.5 or 10 inch core set up to match what you have.
