Re: Mopar Commando heads
[Re: flatiron]
#513012
11/01/09 11:47 AM
11/01/09 11:47 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
there is two..version..well now actually 3 there is a small 177cc intake runner version with rocker stands cast in place. its got killer comb. chambers and with porting can be an ecellent head...more expesive than an assembled eddie though. then next is the larg port commando...its 188cc intake runner..and has larger bowls. the rocker stand mounts are machined off..so it will need the blocks to set up the rocker system.but will accept long valve combos better i understand these heads are discontinued so ..the part number now refers to an iron casting... i dont know if the iron is large or small runner though.. fwiw.. the large port heads can be ported to flow 320cfm..fwiw.. ive seen the small port version..go 290cfm..fwiw
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: S/ST 3040]
#513023
11/04/09 04:03 PM
11/04/09 04:03 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
For comparison, here is a LP Commando with the same valve.
_________INTAKE_____________Exhaust
.100"____54.7________________60.2 .200"____95.7_______________107.1 .300"___141.9_______________142.8 .400"___191.4_______________161.3 .500"___229.8_______________166.8 .550"___241.5_______________167.2 .600"___252.5_______________168.4 .650"___259.4 .700"___263.6
MP 2.02/1.60 No BC OOTB
Note: Exhaust flow will be the same on the small port
EDIT: added a picture of LP Commando
[Re: S/ST 3040]
#513027
11/04/09 04:55 PM
11/04/09 04:55 PM
cheapstreetdustr
i was gonna press fit a dowl in the pushrod bore. and redrill the pushrod hole with stage 6 rocker offset.. although i may go to w2 offset because these rockers are still being made.. then lay back the pusrod pinch in the window to what ever moved the best air. fwiw.
[Re: S/ST 3040]
#513032
11/06/09 09:03 AM
11/06/09 09:03 AM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
I love seeing info like this, hard numbers for incremental changes. Thanks Vic.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#513033
11/06/09 10:10 AM
11/06/09 10:10 AM
S/ST 3040
Oh cool......there's 2 of you. I thought I'd put some stuff up that pertained to the original poster's question. It's a waste of my time to clean the head and flow it after every incremental change. I'll just finish these up and move on to the next job.
[Re: S/ST 3040]
#513034
11/06/09 10:50 AM
11/06/09 10:50 AM
Posts: 5,160 Texas
dannysbee
Texas
I thought the information was great. Please continue and show the end results.
Getting old just means you were smarter than some and luckier than others.
[Re: HEMIDARTS]
#513042
11/07/09 10:50 AM
11/07/09 10:50 AM
cheapstreetdustr
who's being negative? i have sets of these..large ports havent touched them yet.. if someone has data..by all means.. i dont have all the flow charts side by side. i was asking if his opinion was that moving or removing the pushrod pinch was worth it..or not.? I assume the "Idiot" question was directed at me..since iam the only one asking questions..or commenting on technical aspects.. I am no Idoit.. cheapst
[Re: Dos Snails]
#513045
11/07/09 06:26 PM
11/07/09 06:26 PM
S/ST 3040
For all the people who currently own a set of these Small Port Commandos or the aluminum Magnums...........there seems to be a problem with making these thing flow any air. Look at this picture. Apparently the thought was to run these exclusively with a hydraulic roller cam as the pushrod holes are .205" further from the manifold surface than my nasty old OEM heads, which incidentally, outflow these paper weights by 28 CFM. By them being machined as such, places them deeper in the port. Which makes the transition into the curved wall much more abrupt, upsetting the airflow in a bad way. Without relocating the pushrod, I don't see them being a candidate for a serious race application. Flow is 251.3 @ 500" right now.
[Re: S/ST 3040]
#513050
11/07/09 07:19 PM
11/07/09 07:19 PM
dartman366
Mt. Vernon, Ohio
Good Info Vic, I sure am glad that I decided to go with the Lg port Commando's as the flow number's appear to not support what my effort's would require, look's as tho you have put out quite a bit of effort just to obtain what you have from the small port head, but like I have been told before,,,flow isn't everything, I would be real interested in how they work on the motor.
[Re: dartman366]
#513053
11/08/09 06:54 AM
11/08/09 06:54 AM
Posts: 118 Sarasota, Fl
siggie30
Sarasota, Fl
Yes, please continue as I am actively porting my set and am looking for the info. Great read BTW.
I don't even have 1/2 lift, but the other 1/2 is nitroused.
[Re: siggie30]
#513054
11/08/09 11:58 AM
11/08/09 11:58 AM
cheapstreetdustr
cool... Ok here are my thoughts...make sure the pushrod hole is not tapper'd. turn up some aluminum stock, make dowls. put some lock tight on the dowls and press them into the factory pushrod holes. then remachine new pushrod holes.. i was gonna offset them anyway.. then you can modify the port entry to accomidate better air and hit your C/sa..#s it sure seems to have taken alot to unshroud the valves...did you happen to cc them before and after? did i gain alot in cumb.chamber CC? you had to press all new guides in the heads? ouch! cheapst
[Re: cheapstreetdustr]
#513055
11/08/09 12:23 PM
11/08/09 12:23 PM
S/ST 3040
Jim, do you have the small port heads? I added clay behind the pushrod to smoothe the transition. Port hangs on easily to .700" lift now but, flow is dismal with 256.8 @ .700" This port should hit mid 260s @ .500" easy. My mistake for posting any flow numbers, modified without a decent valve job. I'll post chamber volumes later.
[Re: S/ST 3040]
#513057
11/08/09 12:32 PM
11/08/09 12:32 PM
cheapstreetdustr
actually i like seeing numbers before valve job. you can back cut the valve sometimes to fix low lift numbers..if you loose a little when you port..
any way..i have large port heads.. i had small port heads..but sold them... he still has them though ..i could buy them back...but i dont have an application for them. i am going stroker/bigger...next motor... if i determine the LP commandos wont do..ill be getting some indy heads. cheapst.
[Re: S/ST 3040]
#513061
11/09/09 09:00 AM
11/09/09 09:00 AM
Posts: 458 Michigan
BPE
Vic, Stick with it, they will come around. I think putting "real world" info on here is very helpful. Sometimes in life things don't go exactly to plan, but by you posting this it allows others to make better choices. Keep up the good work, and again Thank You. Rod
[Re: BPE]
#513062
11/09/09 03:25 PM
11/09/09 03:25 PM
cheapstreetdustr
no doubt the valves are shrouded.. \even the eddies wil benifit from this. hell..most heads will benifit.. \ thats not a terrible amount gain'd in CC's
[Re: S/ST 3040]
#513067
11/19/09 04:02 PM
11/19/09 04:02 PM
S/ST 3040
OK......my last test on the flowbench after opening the pushrod pinch to 1.010" netted the following: .100"_____62.9 .200"____127.0 .300"____187.9 .400"____229.1 .500"____251.3 Backs up over .500" With valve job and a Ferrea 5050 2.02" .100"_____66.2 .200"____119.3 .300"____176.5 .400"____231.6* .500"____271.4* .550"____280.3 .600"____285.2 346.5 fps @ push rod .650"____285.2 Backs up over .650" * Slight turbulance. Same port but added a 30º back-cut .100"_____68.0 .200"____132.0 .300"____187.6 .400"____240.1 .500"____273.5 .550"____282.9 .600"____282.9 Backs up over .600" I will say this.....68 cfm @ .100" is the most I've ever seen from a 2.02" valve. Must be the nice chamber work. The push rod holes are getting plugged and relocated.
[Re: RyanJ]
#513070
11/19/09 06:20 PM
11/19/09 06:20 PM
Posts: 3,695 nc
emarine01
nc
Just FYI, to anyone who has a set of these heads, might want to start mocking up rockers & checking geometry as MP made a machining error on some (alot from what I can tell) of the Commandos & machined the rocker pedestals to far forward in the head. Another quality MP part.
Maybe thats what the lash caps are for
