Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512634
10/23/13 09:27 AM
10/23/13 09:27 AM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
unit has huge crack on weld to boot....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512635
10/23/13 09:29 AM
10/23/13 09:29 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
original builder made a huge mistake....so we will start over and rebuild this unit....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512636
10/23/13 09:30 AM
10/23/13 09:30 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
tear down to bare case and lets try this again!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512637
10/23/13 09:31 AM
10/23/13 09:31 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
cracked weld in planet
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512638
11/08/13 09:48 PM
11/08/13 09:48 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
UPDATE 11/08
trans rebuilt(by Lee Kapustka)supposed to be sunny@59 Saturday....trans going back in...we will try it again!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512639
11/16/13 11:21 AM
11/16/13 11:21 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
ok great news....trans is back in...Mart Brunke and I worked on it friday...a few minor things left....then we fire it up, go thru gears,check for leaks, and once or twice around the block....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512640
11/16/13 11:21 AM
11/16/13 11:21 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
loctited and tight
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512641
11/16/13 11:22 AM
11/16/13 11:22 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
side view....gotta figure out some wheels and tires that would look good on this slab side ...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512642
11/16/13 11:23 AM
11/16/13 11:23 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
360 old skool...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512643
11/17/13 09:37 AM
11/17/13 09:37 AM
Minnesota
peabodyracing Offline
Minnesota
Way to go Bill! I can imagine how relieved you must feel.
Lead, follow or get the hell out of the way
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: peabodyracing] #512644
11/17/13 12:11 PM
11/17/13 12:11 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Thanks Larry, Having a second trans built right now as a spare, also bought a third trans as a "test" unit. I enjoy R&R ing them so much!the third unit is a A999 lock up,2.74 first gear,5 clutch drum...once the current combo is "worked in"would like to experiment with the lock up trans. use the 2.74 low gear to launch and get a better 60 foot time, a micro switch on the shifter, when i hit third gear it would lock up...A B-body small block combo is not real common...as time&finances allow would like to try an aluminum driveshaft, an aluminum third member,alloy lite weight axles,aluminum radiator, glass hood&scoop,as i think this is my last project...an aluminum headed 408 would be great for 2015....
https://www.facebook.com/photo.php?v=102...e=2&theater
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512645
03/30/14 08:20 PM
03/30/14 08:20 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
drove it today...first time since 2007! out of the garage round the corner, down the street,up the driveway for a bath....neighbors scared of open headers!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512646
03/30/14 08:21 PM
03/30/14 08:21 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
stall converter did not like 2.94 open gear today...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512647
03/31/14 02:15 PM
03/31/14 02:15 PM
Minnesota
Minnesota
Congrats Bill. Looks darn good!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: peabodyracing] #512648
03/31/14 02:37 PM
03/31/14 02:37 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
THANKS Larry! next up is install a aluminum 3 core 22 inch radiator..trans cooler, electric fan...wire the neutral safety switch....swap in the 4.56 pig...still working on wheels&tires, on second set now, saw what i really want at CMC swap meet...15 inch American Torque Thrust Ds...a guy was there with 4 new ones ready to go....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512649
04/23/14 10:37 AM
04/23/14 10:37 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
trial fit of Centerlines...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512650
04/23/14 10:38 AM
04/23/14 10:38 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
4.56 742 traction lock going in...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512651
04/30/14 09:04 PM
04/30/14 09:04 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
still working on rear wheel&tire fitment....15x8 centerlines with 5 inch backspace will not fit...cant go 6 inch backspace,not enough room from tiresidewall to leaf spring&shock mount...might have to drop down to 15x6 or 14x7 rim ...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512652
04/30/14 09:11 PM
04/30/14 09:11 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
that 66 wheelhouse is tiny
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512653
04/30/14 09:12 PM
04/30/14 09:12 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
about three fingers...rim to spring
