Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512614
09/07/13 09:13 PM
09/07/13 09:13 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
fuelish pleasure...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512615
09/08/13 01:35 PM
09/08/13 01:35 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
diggin out my junk in the shed, found this tire&rim, fits perfect! only got 1 any body got 1 more? 15x6? 15x7? not sure of size without dismounting
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512616
09/08/13 01:35 PM
09/08/13 01:35 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
code?
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512617
09/08/13 01:36 PM
09/08/13 01:36 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
older than dirt!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512618
09/11/13 11:09 AM
09/11/13 11:09 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
nostalgic look!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512619
09/11/13 11:10 AM
09/11/13 11:10 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
flashback?
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512620
09/11/13 02:19 PM
09/11/13 02:19 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i'm diggin' on it.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Golden-Arm] #512621
09/12/13 01:26 AM
09/12/13 01:26 AM
central IL reg Nov 18, 1999
Stroker Offline
Stroker  Offline
Sounds good!
When's the next MMCI meeting?
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Stroker] #512622
09/14/13 07:58 PM
09/14/13 07:58 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
well i picked friday the 13th as get some stuff done day.....we bled the brakes, adjusted the shifter, put the hood on, added gas, fired up the engine, 1500 rpm for 12-14 minutes per the builder instructions to break in the cam. engine got to 180,thermostat opened,idled it down, shifted trans into reverse, ok, got reverse, then to "N", ok, into 1st, nothing, 2nd, nothing, 3rd, nothing, no foward gears....full of fluid, have to pull pan, pull valve body and air check some bands and servos...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512623
09/22/13 12:01 PM
09/22/13 12:01 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
OK red fluid everywhere...upside down mess...internal s exposed...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512624
09/22/13 12:04 PM
09/22/13 12:04 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
anybody else mystified by the internal workings of a automatic transmission?LOL i read the ATSG manual,looked online at a guy posting the rebuilding of a 904, next time i leave it to the "experts"
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512625
09/22/13 12:06 PM
09/22/13 12:06 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
no i did not rebuild this....i had a local trans builder "bench' it...it had reverse but no foward gears.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512626
09/23/13 11:14 AM
09/23/13 11:14 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
ok update....a trans guy came by and performed the 4 air checks,all servos&bands are applying....time to call Turbo Action and see if they have ever had that problem before with the RMVB....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512627
09/23/13 09:09 PM
09/23/13 09:09 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
LOL PAUL FORTE from Turbo Action called me back today, he does not know why i would not have foward gears...said to return the valve body to him and they would inspect it, repair it and send it back.I have a spare used one built in 1992 i am going to install tuesday and see if that one works, if not then i guess its pull trans time.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512628
09/23/13 09:14 PM
09/23/13 09:14 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
I went saturday and bought a used 904 trans ,stock,from a 1970 318 Duster...I allready have a new Mancini HP rebuild kit, so I think i will take that trans and have it rebuilt.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512629
09/27/13 05:57 PM
09/27/13 05:57 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Dropped of 904 core&rebuild kit with Jim from Jims Performance(KY),he is a tuner/engine/trans/diff builder who has helped me out in the past.I am pulling the first 904 out and when he brings the #2 rebuild back I will swap them and give him #1 to dissasemble/diagnosis/rebuild. then i will have 1 new one in the car&a new one for a spare for 2014,
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512630
09/29/13 09:10 PM
09/29/13 09:10 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
todays carnage....trans removal...time to start over...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512631
09/29/13 09:10 PM
09/29/13 09:10 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
big gaping hole
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512632
09/29/13 09:11 PM
09/29/13 09:11 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
never got to "flash"
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512633
10/23/13 09:27 AM
10/23/13 09:27 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
10/23 Lee Kapusta tears down my A904 and finds a suprise!sun gear od much smaller than the ID of the 4 gear planet.oops.....
