Re: 4150 to 4500 series adaptors
[Re: Dodgem]
#512433
10/31/09 06:43 PM
10/31/09 06:43 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
If you are serious about performance,avoid the Mr.Gasket short adaptor.I tried one a couple years ago,and the transition is horrible, and the bent studs are about impossible to use. I'm not trying to bust anyone's chops,just real world experience. I ended up buying a Wilson's Manifolds 1" one that is real nice,but pretty expensive. Keith
[Re: Dunnuck Racing]
#512434
10/31/09 07:17 PM
10/31/09 07:17 PM
Posts: 4,647 aotearoa
rebel
aotearoa
you have a part # for that keith? i looked at their site & only spotted a 1.5 ht unit. they look like good products.
[Re: 72demon416]
#512438
10/31/09 09:54 PM
10/31/09 09:54 PM
rebel
aotearoa
If you need a picture of it just let me know.
Rick
need a pic Rick & a part# if you have one. thanx
[Re: 540dust]
#512448
11/01/09 01:44 PM
11/01/09 01:44 PM
rebel
aotearoa
What manifold are you running ?
i've got the indy 400 manifold & hood clearence is tight. but i could go with a shorter air cleaner if push came to shove.
[Re: rebel]
#512451
11/02/09 02:29 PM
11/02/09 02:29 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
Those short 4500-4150 adapters look like they'd be so restrictive that you wouldn't see any performance increase from the bigger 4500 carburetor. Looks to me that if you can't use the taller adapter with a smoother transition, then you'd be better off staying with a 4150 carb or getting the a 4500 flange manifold. CHIP
