Wiring issues (kinda long)
#511844
10/30/09 09:08 PM
10/30/09 09:08 PM
Posts: 3,287 Dalton, MA
Slipknot440
Dalton, MA
Motor is perfect now to play with the wiring.
Car would start and randomly shut off, jiggled some wires around the bulkhead and it would run, move the car a little it would shut down. So I pulled the bulkhead off and found some 30 year old burnt wires (thick black wire, ammeter/alternator, and black wire with white line, horn). Pulled the connectors off and bulkhead replaced the connectors and burnt portions of wires... car wont even start (turns over but doesn't start). Chasing more gremlins i noticed some useless wires (temp, wiper washer motor, and oil) randomly attached to nothing or buried in electrical tape, make shift wires spliced in and out etc. So i pulled the whole middle harness, took off all tape, printed a wiring diagram followed it to the tee (except the violet wire that runs from starter relay to horn) and car still wont start
I have a mallory ignition. I've bypassed the ballast too. Not sure what to do with the dark blue wire that runs to the + coil so i put it back on the coil (hoping it would complete the circuit).
Ideas? Suggestions?
