what stops the cig lighter from being a dead short? #510275
10/28/09 07:53 PM
10/28/09 07:53 PM
Andrewh Offline OP
Andrewh  Offline OP
Might be obvious when I pull it out. But I want to wire mine up again in my coronet.
Is there some isolator that wears out or how it mounts?
Re: what stops the cig lighter from being a dead short? [Re: Andrewh] #510276
10/28/09 07:58 PM
10/28/09 07:58 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
The spiral heating element itself has resistance to it, although not a lot compared to most other circuits.
Re: what stops the cig lighter from being a dead short? [Re: Andrewh] #510277
10/28/09 08:08 PM
10/28/09 08:08 PM
it doesn't make (electrical) contact until you push it in all the way. When the element becomes cherry red it pops back a bit & breaks contact. Except for the controlled resistance in the heating coil it actually is pretty much a dead short for a few seconds until the element heats up & it breaks contact
Re: what stops the cig lighter from being a dead short? [Re: Andrewh] #510278
10/28/09 08:09 PM
10/28/09 08:09 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I think what he means is why does the positve not just short straight to the negative, even without the element in.
Yes, there is an insulator that supports the center contact, and keeps it from contacting the outer housing. I think it's porcelyn. I think they break and fall out after a while.
Contact is made through the lighter element itself, which (as mentioned) has a resistance to it.
Re: what stops the cig lighter from being a dead short? [Re: dave571] #510279
10/28/09 08:28 PM
10/28/09 08:28 PM
I think you're right. I missed that.
Re: what stops the cig lighter from being a dead short? [Re: RapidRobert] #510280
10/28/09 08:41 PM
10/28/09 08:41 PM
Andrewh Offline OP
Andrewh  Offline OP
yeah, that is what I was wondering.
I am afraid the cig lighter in my car is causing a dead short without the element in it. And I was wondering how it was insulated.
Thanks. I guess I will see when I pull it out to be sure.
