Page 3 of 4 1 2 3 4
Re: clogged idle air bleed [Re: sixpackgut] #510104
10/30/09 10:23 PM
10/30/09 10:23 PM
Q
Quicktree Offline OP
Q
niether do
just for you
thats pretty much what I thought. hard to dispute that? no air no fuel.
Re: clogged idle air bleed [Re: Quicktree] #510105
10/31/09 01:46 AM
10/31/09 01:46 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
could also be lots of fuel...
Re: clogged idle air bleed [Re: CokeBottleKid] #510106
10/31/09 02:05 AM
10/31/09 02:05 AM
Detroit, MI
Detroit, MI
Just for you guys... a more respected source than carcraft... sorry for the blurryness.
Re: clogged idle air bleed [Re: CokeBottleKid] #510107
10/31/09 05:50 AM
10/31/09 05:50 AM
Q
Q
shouldn't you be able to see it? along with some black smoke?
Re: clogged idle air bleed [Re: Quicktree] #510108
10/31/09 07:37 AM
10/31/09 07:37 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
idle fuel exits under the throttle blades
Re: clogged idle air bleed [Re: VanishPt] #510109
10/31/09 08:25 AM
10/31/09 08:25 AM
Q
Q
I know but if it got rich enough to shut the motor off you would think you would see some black smoke. the other 2 circuits are not pulling any fuel with the blades closed so I guess it really doesn't matter if they are blocked at idle. I still think it shuts the fuel flow off when blocked.
Re: clogged idle air bleed [Re: sixpackgut] #510110
10/31/09 09:49 AM
10/31/09 09:49 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Was the video posted to show that when you cover the idle air bleeds the motor dies?
If so what did that proove? Did the motor die because it was lean, or because it was rich?
If you really want to know, cover the idle air bleeds. When it starts to die, tap on the accelerator pump (squirting a little fuel). If the extra fuel saves it from stalling, that means it's lean. If the extra fuel from tapping on the accel. pump doesn't do anything, it's alredy rich.
This is how I fine tune idle air mixture adjustment too. RPM goes up with a tap, turn the screw out. RPM goes down with a tap, turn the screw in.
The idle air bleed is there to "lean out" the idle main well on the way to the idle mixture screw. By having a "leak" in the "straw" (idle main well) it's pulling on, it mixes air in with the fuel going to the idle air mixture screw adjustment. The reason that it needs this is because the quantiy of fuel needed to idle is very small. It would be very difficult if not impossible to regulate 100% fuel with the screw adjustment. By adding in a significant quantity of air, the mixture screw adjustment is a lot more forgiving.
To clarify... I'm using arbitrary numbers here just for example sake. Lets say the motor takes 1 gallon of fuel per hour to idle. (or 1gph)
Lets say 1 turn of the idle screw will flow 10gph
of fuel.
With 100% fuel (no idle air bleed) being delivered to the idle screw adjustment, you can see right away, that if 1 turn of screw can turn 10 times more fuel then is needed, then you'd be trying to adjust the screw by 1/10th of a turn to get it right! Much to fine of an adjustment...
Now take the case where you have an idle air bleed. Lets say the idle air bleed hole is big enough that most of the work being done by the vacuum is sucking air, and very little fuel. (lets say 90% air, 10% fuel).
Now you can see I still need 1gph of fuel to make it idle. One turn of screw can still flow 10gph of mixture. However now since the mixture being delivered to the back of the idle adjustment screw is so lean (remember only 10% fuel now), it takes much more of a screw turn to get that quantity of fuel in the engine. In this case, since you can flow 10gph with one full screw turn x 10% mixture, you end up with 1gph fuel in the engine. By doing it this way, the mixture screw can be much more finely adjusted.
Hope that makes sense!
LOL... by the way, the motor is rich. Try turning the idle mixture screws almost 100% in, and I bet it idles better...
Re: clogged idle air bleed [Re: CokeBottleKid] #510111
10/31/09 09:50 AM
10/31/09 09:50 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
now it sounds like you grasping at straws
try putting your finger on the end of one of them
Re: clogged idle air bleed [Re: Quicktree] #510112
10/31/09 09:54 AM
10/31/09 09:54 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
The Dominator idle circuit is silightly different than the 4150 series in that..
1. Trasfer slot is not visable at curb idle below throttle blades. (not all models, but most dominators)
2. idle discharge port is larger than most 4150 carbs
Whith this in mind.
I believe most of the air supplied to the engine at curb idle follows this path.
vaccuum is at plenum of intake manifold (via starter turning engine over)
Air is pulled through the idle air bleed.
Down the idle/transfer discharge channel where it meets the intersection of the idle jet fuel well ( or the brass idle tube discharge) this is where the air/fuel velocities are very high. This intersection is about .5-.75" above the fuel level in the float bowl. pressure here is very low ( high vaccuum- much higher than the intake plenum vaccuum).
Fuel is pulled via high vaccuum through the ifr, where it begins to atomize.
This atomized mixture continues until it meets the idle mixture screw.From ther it enters the idle discharge port as a high velocity properly atomized air fuel mixture into the intake plenum.
Most of the curb idle air comes from the idle air bleed and not the slight opening of the throttle blades.
.....So does the engine die with the idle air bleed cloged because of lack of air? or lack of fuel? .......
For argument sake ( a dominator with the throttle blades completly closed, and the idle air bleed capped) I do believe a stream of fuel is pulled from the idle discharge port in a continuous stream of raw un atomized fuel into the intake plenum . however there is no air. engine will not run or start.Try to cheat and open throttle blades to add air and vaccuum signal drops off and no raw fuel delivery at idle discharge port.
Re: clogged idle air bleed [Re: dizuster] #510113
10/31/09 10:06 AM
10/31/09 10:06 AM
Q
Q
of fuel.
the off idle ports in the pic, is the refering to the intermediate circuit?
Re: clogged idle air bleed [Re: Quicktree] #510114
10/31/09 10:26 AM
10/31/09 10:26 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
2 problems I see with that little video test
1 you used the idle circuit and Tony had the High air bleeds blocked 2 different circuits apples to oranges
2 no proof weather it died from to little or to much fuel.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: clogged idle air bleed [Re: Quicktree] #510115
10/31/09 10:33 AM
10/31/09 10:33 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yes it's the idle transfer slot on a holley.
Re: clogged idle air bleed [Re: dusturbd340W5] #510116
10/31/09 10:34 AM
10/31/09 10:34 AM
Q
Q
everytime I feel confident we get another side guess we need a new movie with the pump shot test
Re: clogged idle air bleed [Re: Quicktree] #510117
10/31/09 10:36 AM
10/31/09 10:36 AM
Kissimmee Fl.
Kissimmee Fl.
cure= clean the carb make sure everything is clear and go make a pass
Re: clogged idle air bleed [Re: dusturbd340W5] #510118
10/31/09 10:38 AM
10/31/09 10:38 AM
Q
Q
I still want to know
Re: clogged idle air bleed [Re: Quicktree] #510119
10/31/09 10:43 AM
10/31/09 10:43 AM
Q
Q
Ray go make another test movie and tap the pump shot. have sombody look at the exhaust for smoke. and clean your garage while your at it.
Re: clogged idle air bleed [Re: Quicktree] #510120
10/31/09 10:53 AM
10/31/09 10:53 AM
Kissimmee Fl.
Kissimmee Fl.
but you are still dealing with 2 different circuits idle circuit tells you nothing about how it will affect the High circuit when the carb is wide open.
Re: clogged idle air bleed [Re: dusturbd340W5] #510121
10/31/09 10:55 AM
10/31/09 10:55 AM
Q
Q
I think we need a 1 circuit carb
Re: clogged idle air bleed [Re: Quicktree] #510122
10/31/09 10:56 AM
10/31/09 10:56 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i could go buy a new o2 sensor also and prove that fuel stops.
IMO, ToddP is the most knowledgeable carb guy we have on this site. go reread his posts. i just happen to agree with him
Re: clogged idle air bleed [Re: sixpackgut] #510123
10/31/09 11:00 AM
10/31/09 11:00 AM
Q
Q
I am with you guys, that was my thinking all along
Page 3 of 4 1 2 3 4
