70 Cuda ralley gauge #506960
10/25/09 01:55 PM
10/25/09 01:55 PM
Tacoma, Wa.
danbs23 Offline OP
danbs23  Offline OP
Tacoma, Wa.
I have the ralley gauges and need to know if there is a smaller oil preasure sender that will work with the stock gauge.
Re: 70 Cuda ralley gauge [Re: danbs23] #506961
10/25/09 05:12 PM
10/25/09 05:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
There's only 2 types of sending units, one for gauges, and one for idiot lights, the gauge type is rather large, and bell shaped in appearance, the idiot light style is very small in appearance, and requires a special socket to install, using the wrong sender will create wrong readings on your instrumentation,...the one you need is SIMILAR to this in appearance
Mike
Re: 70 Cuda ralley gauge [Re: danbs23] #506962
10/25/09 05:40 PM
10/25/09 05:40 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
for gauges:
http://cgi.ebay.com/ebaymotors/New-Mopar...=item562fe8948d
there are two kinds with same shape and looks... 80 PSI and 100 PSI. Both will work, just that scale will be diff reading.
100 PSI were mostly used on trucks as far I know.
Re: 70 Cuda ralley gauge [Re: NachoRT74] #506963
10/25/09 06:44 PM
10/25/09 06:44 PM
Tacoma, Wa.
danbs23 Offline OP
danbs23  Offline OP
Tacoma, Wa.
Thanks for the info. My plan is to install a preasure switch to power the electric fuel pump. It will use the oil preasure port in conjunction with the sender for the gauge. That is why I wanted a small sender so to not have so much weight hanging on the fitting.
Re: 70 Cuda ralley gauge [Re: danbs23] #506964
10/25/09 10:49 PM
10/25/09 10:49 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If you can try to find an OEM mopar oil pressure port splitter from the late 70s through the 80s...It's a big hex shaped adapter that will take whatever you want to hang from it...
Re: 70 Cuda ralley gauge [Re: screamindriver] #506965
10/26/09 03:05 AM
10/26/09 03:05 AM
Tacoma, Wa.
danbs23 Offline OP
danbs23  Offline OP
Tacoma, Wa.
WOW, thanks. Do you know a #PN?
