Re: Will 75 roadrunner mirrors fit 74 B-body?
[Re: 71Furious]
#505681
10/25/09 12:59 AM
10/25/09 12:59 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
pedestals are a little bit shorter, so the cup will fit closer to the door top molding... but will fit. Pedestal shape is diff too.
Angle won't be a problem... they will fit like made to be there.
as stated, need to make couple of holes to the studs since they fit with nuts inside the door.
passenger side control wires will get you to have the joystick below the ashtray area. If you want it there will need some extra holes to get it there. I can't see a problem on that... of course just if you want.
