low deck stroker on a budget?
#505509
10/24/09 06:40 PM
10/24/09 06:40 PM
I have a complete 76 400 4bbl and access to a 440 crank, any ideas on what it would cost to do this? Would one of the new stroker kits be a better way to go financially? Any ideas on what to use for pistons? I would love to hear some combos of guys that have done this. Its just a street motor, I dont want nothing radical.
Re: low deck stroker on a budget?
#505510
10/24/09 06:49 PM
10/24/09 06:49 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I`ve been beating my 470 stroker in two different combos(400 block) both w/eagle rods(chevy 6.385)and a turned down 413 crank. The first combo went 10.40`s and was almost a daily driver w/ported 906`s and a solid Isky cam. The most recent combo has an Isky solid roller and home ported rpm heads and has gone 9.98 and is driven often and is dead reliable. I don`t remember the exact cost but that was almost 9 years ago and I`d probably go w/one of the stroker kits if I was to do it all over again. Both combos use JE pistons are are raced on street tires and mufflers.
[Re: Cab_Burge]
#505513
10/31/09 02:41 PM
10/31/09 02:41 PM
sounds simple, can I use any cam?
#505514
10/31/09 05:18 PM
10/31/09 05:18 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Im in the final stages of building a 451 right now, on a shoestring budget. I opted to use a 413 crank, because I found it on craigslist cheap. I penciled it all out, and going with a factory crank, KB forged pistons, and CAT H-beam rods saved me about $600 vs. a 440-source kit. Might not sound like much, but its those $600 that are allowing me to get a set of stealth heads. So it works for me. I've looked long and hard at every aspect of this build and saved where I could, but still have a good street-strip motor that should last. My budget is currently @ $4,000. However, I am using many parts that are already on my 383 (distributor, intake manifold, oil pan, water pump, pulleys ect.) My combo should be right in the 550-horse range.
I have a complete spreadsheet that shows where my money has gone. I'd be happy to send you a copy if interested. shoot me your email addy.
[Re: StealthWedge67]
#505515
10/31/09 07:42 PM
10/31/09 07:42 PM
how are you ending up at 451 instead of 470?
#505517
11/01/09 06:39 AM
11/01/09 06:39 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
What is radical to you? $4000-$5000? More? Talk to your engine shop, because he will have to do some of the engine work for you. Unless you have your own shop. Ask him the cost and what you can do on your own. Nothing wrong with a shoe string budget if thats what you want to do. Some guy's can do a little more than others. A 451 can be a killer street TQ motor, but so can a stock 400 with a mild solid cam and lets say some, Stealth heads? If it was me, I would sell the 440 crank and do the 511 stroker in the 400. Sound to radical?
Snap your neck, mega G-force launch, is all I want!
#505518
11/01/09 09:09 AM
11/01/09 09:09 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Because he is using the stock 440 stroke, 3.75=451. He didn't say he was going to offset grind the journals to 3.91 stoke=470. I have a 451 in my race car, 1969 Barracuda. I'm sure it could be driven on the street with ease. It is a back halved 2740# with me in it bracket racer. 9.50 @ 140mph. Don
[Re: cudadon]
#505519
11/01/09 03:28 PM
11/01/09 03:28 PM
so if you dont offset grind the crank and leave it at 3.75, what rods do you use?
#505520
11/01/09 05:06 PM
11/01/09 05:06 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
In a low deck a 511, 4.25 stroke, 6.535 rod.....A powerhouse that will take about as much head and cam as you can throw at it.
The 470 is also a great combination, especially in a deep geared or 4 speed app where you don't need the extra grunt from the upper bottom. The 451 is also a great motor, my preference is the shorter 6.36" 383 rod version but both ways are just fine.
Unless it's an A body, In these days with the wide variety of heads available it's kinda hard to justify the low deck 451 over a stock stroke 440 (if you have them both available), the 440 RB is still a Hoss and I'd argue that (even if it's only a couple 100 dollars) whatever extra $$$ the low deck cost money wise over a 440 RB would be better invested towards the heads in terms of total dollars spent.
To put it another way, (and I've built and had about every B/RB motor comination imaginable) I'd rather have a 451RB with a sharp Valve/bowl job than a box stock VJ same-headed low deck for equal $$$.
#505521
11/02/09 05:32 PM
11/02/09 05:32 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
stock length 440 rods
