Re: who makes good piston rings?
[Re: Charger_440]
#505442
10/24/09 05:28 PM
10/24/09 05:28 PM
RapidRobert
I'd say most any plasma moly brand & w KB's no need for the extra expense of file fit (.005" OS rings) as KB's need a greater top ring gap.
[Re: RapidRobert]
#505443
10/24/09 05:44 PM
10/24/09 05:44 PM
Posts: 715 Tulsa, Oklahoma
Charger_440
Tulsa, Oklahoma
i talked to hastings rep the other day, they sound like they have pretty good plasma moly ring set for the 107s. they said there is an 80$ diff in the set w/cast top ring, and the set w/ductile top ring...(i.e. street vs race)
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
[Re: Charger_440]
#505444
10/24/09 07:27 PM
10/24/09 07:27 PM
RapidRobert
yes the moly set is actually a "single" moly set w a moly top ring and a cast 2nd ring as opposed to the cheaper ones that the 1st & 2nd rings are both cast. He said their single Moly set is $80 more than a set of cast ones?. I have not priced rings in awhile but you might check Mancini jegs etc & see if you can scare up a better price for a set of (single) Moly rings.
[Re: RapidRobert]
#505445
05/13/10 01:27 PM
05/13/10 01:27 PM
Charger_440
Tulsa, Oklahoma
what about speed-pro sealed power? had a couple of engine builders recommend them. builders aer saying the hastings rings are like "a bore in a box"...i want something that is gonna last and not tear up the engine or wear it out quick. my ol stock 318 went 264k mi on the original build, what type of ring will last like the originals?
[Re: Frederick]
#505448
05/13/10 06:04 PM
05/13/10 06:04 PM
Charger_440
Tulsa, Oklahoma
any experience with the rings that KB sells?
[Re: Charger_440]
#505449
05/13/10 07:01 PM
05/13/10 07:01 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Brand isnt too much of a big deal on most builds. The more performance you want, the better the ring may need to be. For reference... the top ring is the only one that is coated with molybdenum on a moly set. It is also the only one that is designed to seal combustion pressure, and needs to be matched with the cylinder finish your shop used. Using a moly ring on a cylinder wall that is too rough is a waste because the rough finish will remove the moly. Then it's an iron ring and will need to wear in to seat. Using a plain iron faced ring on the smooth finish a moly ring should have may lead to ring sealing issues because the ring can't seat well. I've used Hastings, Childs and Albert, Total Seal, Sealed power, and Speed Pro. Some parts of kits, some bought seperately. C&A IMO was nicest but most money. I use Speed Pro file fit moly for most of them and they are fine.
[Re: moper]
#505450
05/13/10 07:46 PM
05/13/10 07:46 PM
Charger_440
Tulsa, Oklahoma
rings are one area where i am a little fuzzy...what lasts longest? moly? steel? iron? cast? i dont know. and if i go with a long lasting ring, do i sacrifice anything in exchange for longevity? its going to be a tame LA 360 build, mostly stock except KB 107 pistons and a comp xe-262 cam, so i dont need race tough rings, just good seal and long lasting.
[Re: RapidRobert]
#505451
05/13/10 07:55 PM
05/13/10 07:55 PM
Posts: 374 CONNECTICUT
RoyceFlo73
CONNECTICUT
Hey charger 440, I am building almost exactly the same thing. I am using stock bottom end, but just gonna swap in some KB107s. I am doing just a little bit of block and head milling on my own. But anyways, I have talked to a few engine builders in my area and on moparts as well. It seems the general conclusion has been to use Seal pro rings. I've been told that for a stock-mild build they're great and they're only like 50$ I think. Like stated before, i've been told that the use of moly over a cast come down to the surface of your cylinder bores. If its been fresh honed then I was told to use moly rings. But if not, then i was told moly rings were kinda a waste because the moly coating will wear off pretty quick anyways. Take that for what its worth, it's all second hand knowledge for me. Just passing it along.
[Re: RoyceFlo73]
#505452
05/13/10 09:17 PM
05/13/10 09:17 PM
Charger_440
Tulsa, Oklahoma
itll be a fresh bore. the engine has sat since 1991 and has about 130k on it, so im gonna go .030 over. so moly then?
