Give me some possible reason's why....UPDATE!
#504812
10/23/09 06:47 PM
10/23/09 06:47 PM
dartman366
Mt. Vernon, Ohio
...when I removed the rocker's and shaft's on my smallblock there is a full 1.5-2.0 turn difference in the the adjuster setting from one side to the other, the driver side the adjuster's are out from full seat against the rocker 1.5-2.0 turn's (these are cup style adjuster's), the pass side is out 3.5 to 4. turns from being seated against the rocker, I have been told to run the adjuster out from the seat 1.5 turns, is the mounting pad a different height from the block surface to the pad where the rocker shaft block's are mounted?, I haven't taken the head's off the block yet so it make's it difficult to measure at this time,,I guess what i an trying to get at is I could use longer pushrod's on the pass side to make up the difference, but that is not the way to fix it correctly,I am suspecting factory machining is at fault for this but I could use some other Ideas.
Re: Give me some possible reason's why....
[Re: dartman366]
#504813
10/23/09 07:02 PM
10/23/09 07:02 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I ran into this problem when my machinist milled the stands off my 440-1 heads to switch to Jesel Rockers. This setup adds a few more bolts (4) that goes through each intake runner that attaches a large billet rocker stand bar. Well when I was assembling the engine I ran into this problem as well. 3-4 full turns out form one side to another. He machinist also decked the heads. I knew it had to be in the decking or in the rocker pads. It was in the rocker pads. It was only off .060-.075 inch or so..It doesnt take much...Remember this measurement gets multiplied by the rocker ratio...So .075 mistake here means the pushrods see it as about a 8th inch.
I hope this helps.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#504815
10/23/09 07:25 PM
10/23/09 07:25 PM
dartman366
Mt. Vernon, Ohio
Yes it does help, these head's are un cut except for a light cleanup cut back when Ryanj did them, so it would re-afferm my thought's about factory machining of the stand height, as best as I can figure the stand is approx..030-.035 to high.
[Re: dartman366]
#504817
10/24/09 10:41 AM
10/24/09 10:41 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Bill I had a set of W-2 econo heads that the stands on one head were .120 shorter.... so I had 4 different length push rods... left and right heads and intake and exhaust..... nice machine work from MP
[Re: RyanJ]
#504818
10/24/09 01:04 PM
10/24/09 01:04 PM
dartman366
Mt. Vernon, Ohio
Just curious as to why you're noticing this now, when you have been running them for several years? I would have thought you'd have noticed that the first time you ever assembled the engine? It's always good to doublecheck amount of adjuster sticking out of jamnut on all 16 rockers after you lash valves just a s a "safety measure" to make sure everything was done right.... (pushrod can get caught on lip in lifter etc when lashing giving false setting) So quick glance over everything just to verify all adjusters look aprox same before buttoning up is always good idea.
To be honest I'd say for them to be off that much would be somewhat unusual, although imperfect machining is par for the course for MP/Arrow but I rarely see them off that much. .005" yes.... .035" not much.
Inexperience I suppose, over the last couple of year's I have learned more thing's from this site and notice thing's that I never thought of before, if it weren't for the adjuster's breaking and bringing thing's to my attention I probably wouldn't know the difference, now that both side's are off and I can lay them side by side, then that's when I noticed a large difference, and now I am trying to figure out why, and come up with a solution as to why only one side is an issue.
[Re: dartman366]
#504819
10/24/09 01:18 PM
10/24/09 01:18 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Bill, what kinda rocker gear are you using?? Bolt to the head or use shaft mount like a standard head type( eddie head) would be??
If you are using existing factory attachment points to mount your rocker gear, then it is a factory machining issue. That should have been noted when it was initially mocked up, the pattern at the valvestem must have rolled out( looked) quite different.
If the rocker gear is like mine( Jesel) where you have to mill the head down( mine was around 250-270 thou) to achieve perfect geometry, its possible somebody could have got one side perfect, measured exactly how far they had cut the head, then just cut the other side the same and assumed it would be just like the first side, and not mocked it up.
If would have to be one or the other of the above two things, depending on what you have, in either case a machining issue.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Give me some possible reason's why....UPDATE!
[Re: B3422W5]
#504820
10/24/09 01:55 PM
10/24/09 01:55 PM
dartman366
Mt. Vernon, Ohio
It takes the w2/w5 rocker gear that uses the pad to mount to,,,But I think I just found the problem,,I depth miked from the pad to a small area of the block deck surface and found a .045 descrepancy from one side to the other (the pass side is taller), so it look's to me that the pad's need milled down to match the other, I am also going to have Terry (my machinist) help me double check the rocker alignment and make sure we don't have to make another adjustment with that, it looked good to me when I did it the first time but I have proven to all of you that I still have thing's to learn.
