1978 360 and 727 trans., worth buying? #504322
10/22/09 11:58 PM
10/22/09 11:58 PM
Great White North
71Furious Offline OP
super street
super street
Great White North
Hello,
I found a 1978 360 and 727 trans. which was removed from a Cordoba with low mileage. I'm currently converting my Swinger from a /6 to a V8 and I was wondering if this combo. would be worth picking up and using. Any pros or cons to using a late '70's engine/trans.?
Re: 1978 360 and 727 trans., worth buying? [Re: 71Furious] #504323
10/23/09 12:13 AM
10/23/09 12:13 AM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
I am not sure what year lock up converters started but if it is not a lock up it is worth $75=$100.
Re: 1978 360 and 727 trans., worth buying? [Re: 71Furious] #504324
10/23/09 12:18 AM
10/23/09 12:18 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Hello,
If the price is right, and it all still works good,
I say go fo it. There is a kit at Summit where you
can turn that 360 into a 408 for under a grand.
408 Swingers are very cool. What are your plans?
How about some picts on this new ride.
Snap your neck, mega G-force launch, is all I want!
Re: 1978 360 and 727 trans., worth buying? [Re: BDS871Cuda] #504325
10/23/09 12:33 AM
10/23/09 12:33 AM
hooziewhatsit Offline
If the price is right, and it all still works good,I say go fo it. There is a kit at Summit where you can turn that 360 into a 408 for under a grand.408 Swingers are very cool. What are your plans?How about some picts on this new ride.
Is this the kit you're talking about?
http://www.summitracing.com/parts/SCA-1-98112-1/
Re: 1978 360 and 727 trans., worth buying? [Re: hooziewhatsit] #504326
10/23/09 07:20 AM
10/23/09 07:20 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if it's a good running engine, add a comp XE256, XE262, or lunati 60401 or 60402, and comp 901 springs and go have some fun.
2017 Grand Cherokee Overland
Re: 1978 360 and 727 trans., worth buying? [Re: patrick] #504327
10/23/09 07:55 AM
10/23/09 07:55 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
It don't take much tomake that 360 move that Dart into 13's or 12's for that matter. Some engine work, gears, and tires.
Re: 1978 360 and 727 trans., worth buying? [Re: 71Furious] #504328
10/23/09 08:13 AM
10/23/09 08:13 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I put a basically stock '78 truck LA360 (milled heads, 484 cam, 750 CFM) in my Dart with the stock 904. Runs 8.60 in the 1/8 with street tires.
This is the land of the free because of the brave
Re: 1978 360 and 727 trans., worth buying? [Re: rbstroker] #504329
10/23/09 03:44 PM
10/23/09 03:44 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
It shouldn't take much for a 360 to get into the 12s, & that summit ad is mis-leading, there showing rings/bearings & they don't come with the kit, not that its a bad price as it comes with forged pistons, its still mis-leading, i've already jumped summits azz for having a crappy directory on there sight, maybe i need to jump on them again for mis-leading adds .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 1978 360 and 727 trans., worth buying? [Re: 71Furious] #504330
10/23/09 04:15 PM
10/23/09 04:15 PM
Az
Crizila Offline
Crizila  Offline
Az
Hello,
Nope. It will probably have the smog heads on it, but other than that, you can build it in to what ever you want. Same with the trans. It will have 3 pinion planitary gears and 3 disc front clutch, but you can make it what ever you want.
Fastest 300
Re: 1978 360 and 727 trans., worth buying? [Re: Crizila] #504331
10/23/09 04:21 PM
10/23/09 04:21 PM
alabama
mopars rule Offline
mopar addict
mopars rule  Offline
mopar addict
alabama
I would go for it. It will get you to where you can drive it and then if you are worried about performance you can always pull it later and do what you need to with it when you are ready.
Re: 1978 360 and 727 trans., worth buying? [Re: 71Furious] #504332
10/23/09 08:13 PM
10/23/09 08:13 PM
Great White North
super street
super street
Great White North
Thanks for the input!! I still have a couple of questions...I plan to drive this car on the street with the odd trip to the track(1 or 2 times during the summer)so it shouldn't require too many mods. Any suggestions for affordable heads? If the trans. has the lock-up convertor how difficult and what is the cost to change this over to non lock-up?
Re: 1978 360 and 727 trans., worth buying? [Re: 71Furious] #504333
10/23/09 08:21 PM
10/23/09 08:21 PM
Central Illinois
mity225 Offline
mity225  Offline
Central Illinois
If it was running, buy some Schumacher motor mounts (/6 to SB) and drop it in as is. Have some fun! Then, bump it up a bit with a cam or heads and enjoy the difference!
Always looking for my next project!
Re: 1978 360 and 727 trans., worth buying? [Re: mity225] #504334
10/23/09 10:02 PM
10/23/09 10:02 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: 1978 360 and 727 trans., worth buying? [Re: mity225] #504335
10/23/09 10:03 PM
10/23/09 10:03 PM
Upper Midwest
Upper Midwest
The so called smog heads will not hur the performance all that much for a street engine and they are not that hard to deal with anyway. Yes that set up is worth picking up. Remember when 440's were a dime a dozen too.
Re: 1978 360 and 727 trans., worth buying? [Re: hooziewhatsit] #504336
10/24/09 08:58 AM
10/24/09 08:58 AM
BDS871Cuda Offline
BDS871Cuda  Offline
Yep, thats the kit were useing for the 87 Dodge
4X4 build. Found a good 360 from an 84 pickup.
Thinking about useing RHS 360 X heads or the RPM's.
Joedust 451,
The adds do look a little misleading, heck the
picture isn't even close to what's in the add.
But they do tell you that under the picture.
71 Furious,
The new RHS 360 X head looks to be a good head.
We sure hope to hear more about them before we
order a set. Lot of circle track guys are running
the RHS 360 X head.
Your lock up converter will get you the best
milage on the street. Just call Cope racing trans
and he will have the best advice for you. Maybe
there is a lockup with the right stall that will
work for you. I know a few guys with 12 sec cars
running lockup converters.
www.coperacingtrans.com
219-374-0100 ask for John
Re: 1978 360 and 727 trans., worth buying? [Re: 71Furious] #504337
10/24/09 09:44 AM
10/24/09 09:44 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Hello,
Yeah it should work great, I had almost the same deal- low mile 77 360/727 in my 67 Valiant. I ran the MP 280/.474 cam, performer rpm intake, 3310 holley, headers, B&M 2,400 converter, cheetah MVB and 3.23's, It was a great combo on the street.
Re: 1978 360 and 727 trans., worth buying? [Re: MoparJoe] #504338
10/24/09 04:18 PM
10/24/09 04:18 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
I'd pick it up, if for nothing else than the small block 727. Those are getting scarce around here.
The Blue Goose
My instagram: Bossride
Re: 1978 360 and 727 trans., worth buying? [Re: BossRide] #504339
10/24/09 07:38 PM
10/24/09 07:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I put a 360/999 combo out of a 79 Cordoba in my /6 72 Dart. originally it was a 2bbl 360. Put in a 340 cam, added a 4bbl, had fun for years. No problems. My advice is to just swap it in and run, if you decide at some point you want more you can worry about that then, trust me the stock 360 will be a very nice improvement over a slant.
Two things, are you sure it's a 727? And you will not be able to run the Cordoba's kickdown setup, it's hit the firewall before full throttle.
Don't be the exception.
Re: 1978 360 and 727 trans., worth buying? [Re: Supercuda] #504340
10/25/09 10:38 PM
10/25/09 10:38 PM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
I'm wondering if you're sure if it's a 998 or 727? Most Dobas, unless it was the E58 combo (79 300?) was the smaller tranny. If it is a 727, you might have an E58?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
