Re: Hand or CNC Head Porting ???
[Re: sg66mopar]
#504060
10/23/09 11:21 AM
10/23/09 11:21 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Hey guys, I didn't mean to start a war here. Just wanted to go a couple seconds faster. I'm looking for all the flow I can get from the 440-1s. The motor's 572 inches with over 14-1 compression and with my new cam and rocker combo, around .780 lift. I was hoping to go with B1 MCs but just lost a big chunk of my income so now I need all I can get from my old heads without breaking the bank. I run Super Gas @ around 146 mph and brackets at around 8.90 and 150 mph, but wanted to see something like 8.60 - 8.70 at 155 or more and SG @ over 150.
Dick,no war here.You are maxed out with the 440-1s on a 572" and you would benifit to max them out with the 345cc CNC.The best head combo would be Indy -13 or B-1s or something bigger with a flow of over 400cfm. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: hemi-itis]
#504064
10/23/09 02:22 PM
10/23/09 02:22 PM
isn't it proven by jeff at modern that his cnc program on 906 heads outperformed a hand porter on a FAST build getting a 440-6 RR into the 10 second zone while the hand porter was only able to get the A12 RR to low 11's. ![](/ubbthreads/images/graemlins/shruggy.gif) i believe thats proof enough that CNC'ing one of these heads works better then hand porting. if i were to do it again CNC'ing is my choice,hands down.
A 10sec pass so far has only happened ONCE , Ed had a killer 60ft and has not been able to duplicate it since .
You should stick to what you know ... BBQ'ing skirt steaks ...
John,you should stick to chasing ambulance casualties.You speak with SUCH authority like you are running in the 14's.Correct me if I'm wrong but the top F.A.S.T guys are all going to MCH.And NO!You can't have a peice of steak
AL, i made extra steak for JOHNAHAH at mopars at the valley but he didnt come by to say hi, dont you remember? ![](/ubbthreads/images/graemlins/shruggy.gif) he knows exactly who we are but we dont know who he is! ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) wish JOHNAHAH introduced himself to us.i wonder why. maybe next year,oh well ![](/ubbthreads/images/graemlins/spank.gif)
[Re: sg66mopar]
#504068
10/23/09 06:13 PM
10/23/09 06:13 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
The engine will run good, and you wont need to spin the mill 8K either. 7000-7300 shift points and the engine will live a good while. Hey TS3303 Yes the car was a 225 inch heavy hard tail converted dirt chassis. It was heavy, and ugly..but mainly unsafe. The car had 3/4 ton disc brake calipers and Jeep rotors. LOL..High tech stuff. But it made me feel good when I would be the fastest or next to the fastest cars at the track. But they had M&M slip tube chassis and Undercover 4 link chassis, with complete Mark Williams rear parts. 600" 900-1000 hp Big Chevy's with Sheet metal intakes and twin Alky Dominators etc... LOL My junk had the single small 4150 cast Indy intake with a 4" toilet. SG66mopar That engine will run good. No need to spin the motor to 8K either... 7200-7300 shift points and it will live a long time. ![](/ubbthreads/images/graemlins/thumbs.gif) What rocker gear are you going to run?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: sg66mopar]
#504069
10/23/09 06:14 PM
10/23/09 06:14 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have yet to run them, but got a solid 5% flow improvement by going to a 2.300 intake valve from 2.25, and didn't lose much exhaust flow when they cut the exhaust to 1.78 to make it work. Lets hope the $970 was worth it! Here is a flow sheet,,,,
[Re: Bob_Coomer]
#504070
10/23/09 07:24 PM
10/23/09 07:24 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
I agree with the rpm's. I think that was my next hurdle in trying to run 7's with a 572" -1 motor. The 4.56 gear and 7600 rpms at the stripe were just making the head issue worse. Wanted to try 4.30's but they are always back ordered for a D60. Tall gears and let that beast grunt, try to keep it under 7200.
