J.E. Piston Profile for Indy head #503211
10/21/09 08:06 PM
10/21/09 08:06 PM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
I have a set of J.E pistons that were made for indy small block head 360 rectangular port heads.
My qestion is can these pistons be re profiled for a W-9 50cc heads.
Specs. for my current pistons are
4.060 bore
.300 dome
1.200 comp ht.
.043,.043,3mm rings
.927 pin
2.75 pin length.
I want to go with a w-9 head but dont want to buy pistons unless I have to.
Re: J.E. Piston Profile for Indy head [Re: FIREGUY12] #503212
10/21/09 08:26 PM
10/21/09 08:26 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
anyone know?????????????????????????Please
Re: J.E. Piston Profile for Indy head [Re: FIREGUY12] #503213
10/22/09 08:57 AM
10/22/09 08:57 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
It will need mocked up in a block W/ a 9 head, one of biggest things is to watch for plug interference into the dome, W9's notorious for that.
Also obviously that piston is 18 degree & a W9 is 15 or less... also W9 going to generally have bigger diameter valves & slightly different valve spacing than an ICH head, those are your 3 areas of concern. The dome should fit a 9 chamber other than the aforementioned plug angle issue.
Usually it is not a big deal to make a 18 degree piston work with a 8/9 head. Just have to play with reliefs. Keep in mind if they had made that piston for a W9 app, it probably would have started with same forging....
Re: J.E. Piston Profile for Indy head [Re: RyanJ] #503214
10/22/09 09:56 AM
10/22/09 09:56 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
Thanks Ryan for answering my question.
