acc pump check valve #502839
10/21/09 01:29 PM
10/21/09 01:29 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
ball kind or rubber seal kind ?
which one is better or would you choose ?
the ball kind is REALLY GREAT becaus is strong and easy to reuse, but, dunno about if ball seals good.
Re: acc pump check valve [Re: NachoRT74] #502840
10/21/09 01:43 PM
10/21/09 01:43 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
They both work well, but I've found the new style rubber one easier to service (replace). The steel ball can get corroded and stuck, and servicing it with the little brass "tang" by bending it, or removing it is a pain.
