How do you remove 67 B post car side glass? #502262
10/20/09 06:59 PM
10/20/09 06:59 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I'm trying to remove the front and rear side glass from my 67 Belvedere post car, and I was curious if there was any trick to doing it? It appears the front may need the wing window reoved or loosened?? Any help or tips would be appreciated.
Re: How do you remove 67 B post car side glass? [Re: NV69B7RR] #502263
10/20/09 07:32 PM
10/20/09 07:32 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
On the door glass, you need to unscrew the little rubber top of the vent glass. Yes, there is either a tiny screw or rivet holding this rubber piece on. This allows the glass to slide up and out.. Of course this is after you unhook it from the regulator... Sometimes it easier to unbolt the regulator from the door, or qtr panel, the get the glass off of it..
Qtr panel, just start taking stuff apart
