Broken Bumper Bracket Nut - 70 Challenger
#502140
10/20/09 03:44 PM
10/20/09 03:44 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
On my R/T, one of the front bumper bracket mounting nuts is broken off (welded to the inside of the frame). What would be the best way of repairing this? I assume I would need to cut the frame rail open, weld in a new nut and weld the rail closed again. Is there a better way? ![](/ubbthreads/images/graemlins/shruggy.gif) I want to repair this soon so I can get it mounted on the rotisserie for winter.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Broken Bumper Bracket Nut - 70 Challenger
[Re: 6T6Cuda]
#502142
10/20/09 04:15 PM
10/20/09 04:15 PM
Erik
Stroudsburg, PA
I don't quite understand what you mean by drill a hole. Do I drill a hole to get to where the nut was and weld in a new nut then seal up the hole?
I am also confused by the bracket reference. I have never seen a bumper bracket welded to the frame on any Challenger I have had.
Do you have any pics to explain what you mean?
[Re: Erik]
#502143
10/21/09 02:17 AM
10/21/09 02:17 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The factory nuts are enclosed in a metal cage, or have wings (ears) on them and the cage or ear is welded to the frame rail. I believe he is proposing that you drill a small hole in the area where the cage or ear should be and then weld thru the frame rail and attach the cage with that weld., then brush the weld flat and done. No structual damage to the frame. The hard part will be positioning the nut for welding..,since it is probably laying somewhere in the frame rail .... Another suggestion is to drill a hole with a hole saw from the opposite side of the frame rail and insert and weld from the inside, then use the slug and weld close the hole. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Erik]
#502144
10/21/09 05:09 AM
10/21/09 05:09 AM
Posts: 1,757 Phila
PhillyRag
Phila
here's pic of my 70 challenger. MAybe it'll better able you to understand.
The Pink dots would the drilled holes in the rail. Then need to Plug weld thru holes onto the face of the bolt that surrounds the threaded opening. Then grind down. This area is hidden once bkts are in place. Holes approx. 1/4" or larger, depends on how larger the bolt surface is that in the frame. Tricky part is retrieving the bolt & aligning it back into place. Sure beats cutting a plate out of opposite end (which is visible) & welding/finishing it nicely.
[Re: PhillyRag]
#502145
10/21/09 08:04 AM
10/21/09 08:04 AM
Erik
Stroudsburg, PA
Pic doesn't work.
I was gonna go in from the back side like stated above. I need go get out in the garage and take a better look at it again.
