Page 5 of 5 1 2 3 4 5
Re: 25 MPG with a 408 ??? Yup!! [Re: DaytonaTurbo] #500662
10/24/12 06:06 PM
10/24/12 06:06 PM
USA
Hooligan Offline
Hooligan  Offline
USA
Hey! Does a high volume oil pump have an adverse affect on the MPG's, as opposed to a stock oil pump???!
Re: 25 MPG with a 408 ??? Yup!! [Re: Hooligan] #500663
10/24/12 10:52 PM
10/24/12 10:52 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i would say yes to the high vol oil pump.. a stock pump is fine for the street
good job on the mpg, i wanna do the same with my 318 dart..
Re: 25 MPG with a 408 ??? Yup!! [Re: Hooligan] #500664
10/25/12 10:53 AM
10/25/12 10:53 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It's More to do with pressure. the high volume pumps tent to build more pressure and building pressure takes power so some parasitic loss! all ads up.
But for safety at RPM a like a high volume pump with and light or adjustable releif spring so you can set your max pressure at say 65 not 110 but it still has the volume when called for.
this is with 1/2 15/40 and 1/2 5W 50 motor was cool
http://www.youtube.com/watch?v=kmvZNkBHfUU&feature=plcp
this was on enital start up this summer went to 68 I think dead cold.
Course the alt quit just as I mentioned it wireing issue took ot the regulator all fixed now.
http://www.youtube.com/watch?v=YvhENA8svJY&feature=plcp
Re: 25 MPG with a 408 ??? Yup!! [Re: Dodgem] #500665
10/25/12 12:08 PM
10/25/12 12:08 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
it has to do with volume as well you can't build pressure if your bearings are sloppy and leaking all over. if you have tight bearings then no need for a high volume pump. hydraulic horespower is calculated by hhp=pressure*flow/constant.
therefore both components are equally important when figuring parasitic loss. if you don't need a high volume pump don't use it.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 25 MPG with a 408 ??? Yup!! [Re: Jerry] #2814065
08/27/20 07:42 PM
08/27/20 07:42 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Did someone say larryLOVEits 408 was getting 25 plus ?
With THAT FACT and his installation of those greyvvelore seats ...
I’ll bounce my offer up aNutter 1k$ up
Re: 25 MPG with a 408 ??? Yup!! [Re: dOc !] #2814186
08/28/20 12:19 AM
08/28/20 12:19 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Hey Bro! Not sure what brought this up tonight, but 8 years ago was "in the past." Dudes don't talk about that stuff...
Re: 25 MPG with a 408 ??? Yup!! [Re: Fat_Mike] #2814189
08/28/20 12:25 AM
08/28/20 12:25 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
AM ... FM ... I saw someone viewing the topic and decided to post...
Dudes don’t talk about what ?
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #2814227
08/28/20 09:14 AM
08/28/20 09:14 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I used to get high teens with the 440 in my 3/4 ton crew cab. Yeah, its entirely possible to hit 20s in a car.
Congrats!
