Page 4 of 5 1 2 3 4 5
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500642
10/23/09 07:27 AM
10/23/09 07:27 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
IS THERE A TUNNEL RAM INTAKE THAT BOLTS UP TO MAGNUM HEADS?? Sorry about the caps.
yes....if you redrill them to LA pattern
2017 Grand Cherokee Overland
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500643
10/23/09 08:13 AM
10/23/09 08:13 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I'm assuming this was mostly, if not all highway??
All highway except for a little drag race with a mustang on the freeway. (guess who won?)
I'd be interested in how the car does around the town. Thats where the T-quad will really shine. Steady RPM on the highway, you probably wont see much mpg diff with any other carb if A/F ratio is the same. But from stop light to stop light, the tiny primaries will be better suited.
How it will work with the tranny & rear ratios will be interesting.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500644
10/23/09 02:19 PM
10/23/09 02:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
curious as to why you did not run 34 with 11 vacuum added on to achive the same cruise advance but have a little more WOT for more performance???
Re: 25 MPG with a 408 ??? Yup!! [Re: Dodgem] #500645
10/23/09 02:45 PM
10/23/09 02:45 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Everything I have read says that the more efficient combustion chamber of the magnum heads needs less advance. This also helps lower pumping loss at cruise. When I take it to the track I'll play with the timing to see if i can squeeze a little more out of it.
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500646
10/23/09 03:21 PM
10/23/09 03:21 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
The more efficient the chamber and port design, the less time you need for combustion (meaning, less ign advance), the less negative torque that will be created, and the less heat that will be lost to the cooling system.
All adds up to more fuel efficiency.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: 25 MPG with a 408 ??? Yup!! [Re: Fury Fan] #500647
10/23/09 03:28 PM
10/23/09 03:28 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The less timing required, the more efficient the combustion system (heads, chamber, piston, ignition).
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 25 MPG with a 408 ??? Yup!! [Re: Rapid340] #500648
10/23/09 03:43 PM
10/23/09 03:43 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
my mild 318 (combo listed above) seems to like 32 or so degrees of total advance for best power and economy. I'm using a 17 degree vac advance can on the dizzy, for a total of 49 degrees of cruise advance.
Re: 25 MPG with a 408 ??? Yup!! [Re: patrick] #500649
10/23/09 03:48 PM
10/23/09 03:48 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
I wonder what will make more power? 87 octane with a little timing pulled out or 91 octane with a couple degrees more timing advance??
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500650
10/23/09 04:49 PM
10/23/09 04:49 PM
#2
Re: 25 MPG with a 408 ??? Yup!! [Re: RapidRobert] #500651
10/23/09 05:59 PM
10/23/09 05:59 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500652
10/23/09 07:25 PM
10/23/09 07:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Depends on if what the engine needs. Normally in my experiance the magnum heads work best 32-34 mechanical advance. When I had my 318 mpg motor it really ran better with a very short mechanical advance and a short vaccume advance. If I remember the sweet spot for mechanical was 18 initial and 32 total. The shortest vaccume advance can I found was 8.5 and it did the best, I think it would have really liked a couple less total degrees. Once I got it all tuned right it ran the same on 87 octane as 93 and neither one wanted more advance. I am now at 3000 ft elevation so that lowered my preasure a hair.
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500653
10/24/09 12:36 AM
10/24/09 12:36 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Great work
I wonder if a six pak would do even better. I am glad to see someone put some thought into having a fast [but old] car & gas mileage just like new tupperware can... [Tupperware refers to a corvette-plastic container with an airtight lid...]
Have you put synthetic fluid in the diff??? Anything synthetic for lubricants will help raise the mileage as well.
I have a very strong 416 six pak in an E body with overdrive that got 16 mpg going to & from Carlisle 180 miles each way. Speed was 55-70 mph mostly on cruise control. I'd show the naysayers my log book for the car but that's classified info.
Re: 25 MPG with a 408 ??? Yup!! [Re: Mr.Yuck] #500654
10/25/09 07:49 AM
10/25/09 07:49 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
putting a 2.261 gear in a muscle car that you spent all kinds of $$$ building a 408 storker is like neutering your prize race horse because you want him to live longer.... if you wanted MPG's you could have just rebuilt a 318 and used a 2bbl throttle body.
I love the idea of cubes and tall gears. GM did it with the previous generation Camaros. 5.7L with a 0.50 overdrive. 25-30 mpg and 13 second quarters.
Small engines can't be run down the highway with tall overdrives. Most 4 cyl cars are above 3000rpm on the highway.
Plus a 318 and a 2 barrel would be gutless compared to Dmercs combo. Power and mileage, that's a goal worth chasing.
Magnums engines will not take advance like the LA headed engines. I've run my best times in my 5.9 Magnum at 30 deg total.
Great work Dmerc. Your 408 has surpassed my best MPG of 23. With some similarities. I'm also Magnum headed but with stock cubes, 360. Also overdriven but with 5 speed manual and 3.55's.
In a truck plagued with poor aerodynamics but as you I also firmly believe in vacuum advance. I run 18 vacuum on top of my 30 mechanical for a total of 48.
Keep us posted on your 1/4 mile results. I predict you will have no problems surpassing 14's.
Re: 25 MPG with a 408 ??? Yup!! [Re: Magnum] #500655
10/25/09 01:11 PM
10/25/09 01:11 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Thanks Magnum. I did go to the track yesterday and it did not go well. Car would launch flood out die. did it twice. I think the choke pull off is the culprit. It also functions to slow the opening of the secondary air valve. I've taken the choke pull off... off. This only happens at the drags when I really hammer it quickly.(in front of hundreds of people!) I'll know next week. I'm going to try again!!!
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500656
10/23/12 05:52 PM
10/23/12 05:52 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Shameless with hopes for some updates
Re: 25 MPG with a 408 ??? Yup!! [Re: Skeptic] #500657
10/24/12 09:00 AM
10/24/12 09:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
dmerc's last post was over a year ago...you might be waiting a while
Re: 25 MPG with a 408 ??? Yup!! [Re: RapidRobert] #500658
10/24/12 09:06 AM
10/24/12 09:06 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500659
10/24/12 10:17 AM
10/24/12 10:17 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
Sounds like a great combo! Looks like you're really on top of this project, but I have to ask. Is your odometer/speedometer calibrated?
Re: 25 MPG with a 408 ??? Yup!! [Re: 63stabamatic] #500660
10/24/12 01:51 PM
10/24/12 01:51 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Oh well interesting thread anyways.
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500661
10/24/12 02:07 PM
10/24/12 02:07 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Way to go, Dmerc.
These great cars do NOT have to be "single purpose" machines. Efficiency crosses many lines and a clean running engine can be fast and fuel efficient.
Late model cars are compromises of the big 3 factors: Emissions, economy and performance. YOUR efforts are in line with the OEMs, and it should be congratulated. Nice work.
My car will never see 25 mpg even driving downhill with 90 series tires and the trans in neutral. I do plan on improving the combination to maximize mpgs, but there are some points to which I will not concede. I will not modify the exterior, change the tires or switch to a smaller engine. The T-Quad carb could be the single most effective modification to improve mpgs. Your efforts are paying off, and posting them here will certainly help others reach their goals.
Thank you.
