I use the 1970-71 stock street Hemi-440 6 pak pan on my street pump gas stroker motor, I shift it at or above 7000 RPM at the track. No problems on the street or track
As far as the head gasket what does the deck on the block feel and look like? I had one of the new(not one of the newest World blocks) Hemi blocks that I did not deck and it leaked like a fiend, I had to take it apart and have the block decked(cut) to the proper finish, the stock finish was way to course to seal with strock steel shim head gaskets
It sealed fine afterwards
I use the .0045 per inch of bore on the top ring and a littel looser(.002 to .004 ) on the second ring
Top ring, .0045 x 4.375=.0196 or .020
.024 to .026 on the second rings
