Urethane bumper paint prep ? #497885
10/15/09 12:18 PM
10/15/09 12:18 PM
North Dakota
440abody Offline OP
440abody  Offline OP
North Dakota
I have a new bumper cover for my wife's 05 Magnum, that needs to be painted. What is the proper/best way to prep the urethane cover so the paint will stick and not flake off in 6 months.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: Urethane bumper paint prep ? [Re: 440abody] #497886
10/15/09 02:48 PM
10/15/09 02:48 PM
Arkansas
beatupcuda Offline
beatupcuda  Offline
Arkansas
Most people make the mistake of not putting a flex agent in the primer, flaking off is poor prep work or lack of sanding adhesion properties.
On a new "bare" bumper, completely clean with a degreaser, prep solvent,
either sand or heavy scotch bright, then apply primer, sand again, unless it's self etching type,
there has to be a step here for adhesion, ask your paint supplier, what he is selling you.
Re: Urethane bumper paint prep ? [Re: 440abody] #497887
10/15/09 03:05 PM
10/15/09 03:05 PM
Jacksonville Florida
elitecustombody Offline
the bumper comes already primed with flexible primer from the factory ,if it's OEM bumper,I use "Scuff Stuff" paste and red scotch pad ,rinse it off, apply two wet coats of Plastic Magic adhesion promoter and follow with color and clear. Never had adhesion issues ,I love using this stuff, it works great on raw plastic bumpers too
do a google search on these products,most paint supply stores have it in stock .
whatever you do, invest in some adhesion promoter,
