Tips on replacing head gasket on 360??? #497739
10/15/09 10:39 AM
10/15/09 10:39 AM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
It has been determined by an old Mopar mechanic that the head gasket on my 360 Magnum motor is bad on the drivers side and I have purchased the parts to replace. What are the steps to disassemble and reassemble? I would like to start on this this weekend.
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: Tips on replacing head gasket on 360??? [Re: twister360] #497740
10/15/09 12:40 PM
10/15/09 12:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would suggest going to the library and looking at a repair manual.
Re: Tips on replacing head gasket on 360??? [Re: twister360] #497741
10/15/09 12:56 PM
10/15/09 12:56 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Disconnect your battery
Drain as much of your coolant as possible.
Remove your carb, kickdown to intake linkage, intake etc.
Remove the ground from the front of the head, the exhaust manifold, possibly from the pipe too if you need to.
Remove the valve cover, then the rockershaft assembly.
Take the pushrods out and make sure you mark or put them in an order so they go back to the right lifter AND the correct end down (I like to do that anyway).
Loosen your head bolts but try not to remove the, so you don't get them mixed up, some coolant will probably spill down into the cylinders. Take the head off, you may need to wack the sides gently with a rubber hammer, or there may be a tang you can't pry from a little with a big flatblade screw driver.
Soak up all the anitifreeze off the tops of your pistons. Cover the rest of the motor good and spray some WD-40 on the tops of those pistons and blow it with an air blower from your compressor, just to make sure most the fluid is out. Put a little oil around the edges to keep it from rusting while your working.
Clean the top of the block thouroughly, make sure no trash got into the cylinders, is so, remove it. Do the same to the face of the head.
Clean the top of the block with a good solvent like laquer thinner or etc.
Then do the oppoisite for reassembly. Torque to specs and in recommended sequance for heads, rockershaft, intake, etc.
After your done, do an oil change to make sure no coolant is left in your oil and fill it back up with coolant.
Re: Tips on replacing head gasket on 360??? [Re: JoesMopar] #497742
10/15/09 02:04 PM
10/15/09 02:04 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
you forgot the gasket
Re: Tips on replacing head gasket on 360??? [Re: west] #497743
10/15/09 02:33 PM
10/15/09 02:33 PM
scratchnfotraction Offline
what yr and vehical is it?
magnum 360?
Dak...ram 1500...older car ans swaped in the manum?
still got the manum keg intake and serp belt?
little more to it than an older LA 360,basics are the same but there is a little tid bit of info thats need for the mag stuff
like intake bolts only torque to 144 inch pounds..things like that..
Re: Tips on replacing head gasket on 360??? [Re: scratchnfotraction] #497744
10/15/09 03:25 PM
10/15/09 03:25 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Two of the big thing in a succesful head gasket replacement one is cleanliness and the other is making sure that the head is true. Thake it to a good machinist and have him check it and make sure that it is perfectly flat. The head is the most likely to get slightly distorted.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Tips on replacing head gasket on 360??? [Re: MoparforLife] #497745
10/15/09 05:22 PM
10/15/09 05:22 PM
you want it good the 1st time. the intake bolts are numbered 10-6-2-4-7-11 front to rear on the pass side. 9-5-1-3-8-2 on the drivers side front to rear. torque bolts 1 thru 4 in 12 INCH lb increments to 72 INCH lbs then the remaining bolts (5-12) to 72 INCH lbs (in order). Check that ALL are at 72 INCH lbs by (re)torquing them in order, then torque ALL to 144 INCH lbs in sequence & recheck all of them in order for 144 INCH lbs.
Re: Tips on replacing head gasket on 360??? [Re: RapidRobert] #497746
10/15/09 09:04 PM
10/15/09 09:04 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Shop vac comes in real handy for getting the crap out fo the cylinders/etc. Too...
Re: Tips on replacing head gasket on 360??? [Re: Bill MeLater] #497747
10/15/09 09:55 PM
10/15/09 09:55 PM
I use the shop vac as I am scraping the gasket surface to keep it clean and junk out of the cyls
Re: Tips on replacing head gasket on 360??? [Re: scratchnfotraction] #497748
10/16/09 11:14 AM
10/16/09 11:14 AM
Houma, Louisiana
Houma, Louisiana
magnum 360?
The engine is in a 74 Duster and the motor is a 360 Magnum from a ram truck, dual plane air gap intake and holley 3310 carb. Also has headers and PS and PB. Will the headers and power accessories be much of a problem. What is the torque for the head bolts and should I resue them? I plan on taking the head to the machine shop to check if it is square and check the valves. Anything else I should do? Thanks
Re: Tips on replacing head gasket on 360??? [Re: twister360] #497749
10/16/09 11:38 AM
10/16/09 11:38 AM
Upper Midwest
Upper Midwest
105 foot lbs. In x pattern starting in center and working end alternating side to side top to bottom, small increments.
No need to replace bolts.
Re: Tips on replacing head gasket on 360??? [Re: MoparforLife] #497750
10/16/09 11:41 AM
10/16/09 11:41 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
To save future grief you need to do both at the same time. While you already have most ecverything off it's not that much extra work or cost.
Re: Tips on replacing head gasket on 360??? [Re: twister360] #497751
10/16/09 11:43 AM
10/16/09 11:43 AM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
Don't forget to get the cylinder head checked for cracks. we have seen more than a few cracked.
This space available for rent
Re: Tips on replacing head gasket on 360??? [Re: cptn60] #497752
10/16/09 04:45 PM
10/16/09 04:45 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I would be looking at why the head gasket failed
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Tips on replacing head gasket on 360??? [Re: 65signet] #497753
10/16/09 06:21 PM
10/16/09 06:21 PM
Exactly. Pay him to come over & check the decks w his straight edge also.
Re: Tips on replacing head gasket on 360??? [Re: RapidRobert] #497754
10/19/09 10:30 AM
10/19/09 10:30 AM
Houma, Louisiana
Houma, Louisiana
Thanks for all the info.
Too busy this past weekend to get started on the repairs.
Re: Tips on replacing head gasket on 360??? [Re: cptn60] #497755
12/01/09 03:34 PM
12/01/09 03:34 PM
Houma, Louisiana
Houma, Louisiana
I took the head to a machine shop and the head gasket was definetly blown. Had the head checked and had 2 cracks in that particular part of the head. The spark plug was black and it was not firing at all. The machinest said the head cracked because of the failed head gasket. Had to get a replacemant head and had a valve job done and had the head checked to see if it was perfectly flat. I put it all together this past weekend and fired it up. It actually runs pretty good now even with a lopey cam. It is now running on 8 cyclinders and not 7 as before. I let the engine run for about 30 minutes, looking for leaks etc. and checking for anything out of the ordinary. Is there anything I should do to assure myself that everything is in order, as I have never done this type of job on the car before?
Thanks for your help.
Re: Tips on replacing head gasket on 360??? [Re: twister360] #497756
12/01/09 04:40 PM
12/01/09 04:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Runs good, no leaks, you're done.
Re: Tips on replacing head gasket on 360??? [Re: JoesMopar] #497757
02/28/15 12:14 PM
02/28/15 12:14 PM
houston, tx
d100clubcab Offline
d100clubcab  Offline
houston, tx
Loosen your head bolts but try not to remove them,
Any "easy" way to get these bolts out?
I was able to use my cordless impact on a few of them but the ones I need to to do by hand are STUCK
ideas?
Re: Tips on replacing head gasket on 360??? [Re: d100clubcab] #497758
02/28/15 01:41 PM
02/28/15 01:41 PM
I was able to use my cordless impact on a few of them but the ones I need to to do by hand are STUCK ideas?
use a 1/2" breaker bar & a cheater pipe on the end of it if needed. maintain the socket/extension in line with the bolt head (pretty much vertical) & the breaker bar/cheater out horizontle at a 90 deg angle & jerk the handle rather than a steady pull to break (em) loose
