Dana.... Drive shaft, How much shorter
#495599
10/12/09 05:56 PM
10/12/09 05:56 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
I bought a S60 DANA from a member here for my GTX also I know the snout/Pinion of Dana protrudes out farther than a 8 3/4 anyone know how far so i can give an exact measurement. Before I go to the driveshaft store.
Re: Dana.... Drive shaft, How much shorter
[Re: 10secGTX]
#495603
10/12/09 08:53 PM
10/12/09 08:53 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
From the MP specs the Factory Dana is snout protrudes 1.12" further then the 8.75 rear. So about a 1" difference. I dont know if the specs are the same for the S60 after market Dana. I would definately put it in first and then measure to find the optimum length driveshaft. So NO, to the Driveshaft shopping before the rear is installed. mike
