318 dual quad poly motor questions #495479
10/12/09 03:39 PM
10/12/09 03:39 PM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
Came across this dual quad poly casting number is 2264370 on the front pass side of the block. I can not find a date code like a later motor has. How can I tell if this is an original dual quad motor? The reason I ask if you look at the photo it does not seem to be messed with it looks like the intake has been on it untouched as the rest of the motor for a long time. Any help from a knowledgeable poly-guru would be greatly appreciated
Re: 318 dual quad poly motor questions [Re: 69four46] #495480
10/12/09 03:47 PM
10/12/09 03:47 PM
is that a 1963/64?
Re: 318 dual quad poly motor questions #495481
10/12/09 04:20 PM
10/12/09 04:20 PM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
is that a 1963/64?
I don't know the year that is what I am trying to find out. Thanks
Re: 318 dual quad poly motor questions [Re: 69four46] #495482
10/12/09 04:54 PM
10/12/09 04:54 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I think the dual quad poly motors were made from '57ish to '58. Don't think any were available in the 60's. Should also be a 290HP motor IIRC. What are your plans for it?
Re: 318 dual quad poly motor questions [Re: JoesMopar] #495483
10/12/09 05:15 PM
10/12/09 05:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
57/58 Poly 318 engines looked like that, another tip off is the early poly valve coveres, later ones didn't have the retaining bolts through them. It's most likely from a 57/58 Fury.
Re: 318 dual quad poly motor questions [Re: ScottSmith_Harms] #495484
10/12/09 05:22 PM
10/12/09 05:22 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
should be a date on the right side of the block toward the rear, or a p/n or date on the intake manifold somewhere.
mine also had some stampings on the drivers side intake rail, rear, right next to the distributor.
Bolts thru the valvecovers WAS also on the later motors.. My 65 has them.
Re: 318 dual quad poly motor questions [Re: SSAAHemiFan] #495485
10/12/09 05:28 PM
10/12/09 05:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, I should have said "Some"
Re: 318 dual quad poly motor questions [Re: ScottSmith_Harms] #495486
10/12/09 06:49 PM
10/12/09 06:49 PM
Chesapeake Va
BobK Offline
BobK  Offline
Chesapeake Va
All polys had bolts through the valve covers. The 57/58 polys had 3 bolts holding them down. That engine is a 60's poly by outward appearances.
1964 Plymouth Fury x 2
1964 Plymouth Sport Fury
Re: 318 dual quad poly motor questions [Re: SSAAHemiFan] #495487
10/12/09 07:40 PM
10/12/09 07:40 PM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
right side meaning drivers side rear? also was the dual quad option only those two years 57 & 58? if so then the intake should have that date on it. Thanks
