Re: To all the haters and everyone else. The R5 is IN!!!!!
[Re: emarine01]
#495163
10/12/09 01:30 PM
10/12/09 01:30 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Looks good to me Go getem on the ice Its posts like this that make me feel bad about my 59* junk Good luck & go kick some azz
The ice is a blast, I wish more of you guys could come up and see it...
The current record is 5.592 in the 1/8 on glare ice
Don't feel bad I've had slow 59* stuff for over 10 years. This is my first 9 sec engine and it took almost 4 years to do.....
[Re: SB449VALIANT]
#495166
10/12/09 02:27 PM
10/12/09 02:27 PM
DemonDust
Menomonee Falls
i still stuck with the 59* stuff, im very happy with my last results,i think iam not ready for the more exotic stuff that is out there.....i know how you feel with your new project...proud haa!!!
I'd still have 59* stuff if your neighbor Kelly didn't bend me over for over 6k... But then again there are alot of people on here that were taken by him
[Re: DemonDust]
#495167
10/12/09 03:03 PM
10/12/09 03:03 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
6k... WOW!!!! i only meet him once at the Houston race track....did't do any business with him
[Re: SB449VALIANT]
#495168
10/12/09 03:59 PM
10/12/09 03:59 PM
DemonDust
Menomonee Falls
You're lucky. He seems like a great guy. He's def a good salesman.
[Re: DemonDust]
#495171
10/12/09 04:47 PM
10/12/09 04:47 PM
Posts: 5,000 Tampa Florida
dc426
gotta keep'm separated
Tampa Florida
[Re: Quicktree]
#495174
10/12/09 05:02 PM
10/12/09 05:02 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
the airpocket that you keep having may be caused by the fitting right off the intake to the radiator, try and find a low profile fitting so it doesn't "pitch" the hose up higher then the radiator. after looking again, ditch the 45 and just use a 90 Looks good
[Re: DemonDust]
#495176
10/12/09 05:31 PM
10/12/09 05:31 PM
Posts: 2,578 sweden
1Fast340
sweden
[Re: prochargedhemi]
#495177
10/12/09 06:55 PM
10/12/09 06:55 PM
DemonDust
Menomonee Falls
Looks good
Looks can be deceiving......
After lots of brain stumping I started tearing it apart. Water pump was fine, drained the block, water manifold gaskets lined up perfect, but when I took the manifold off water came out. The heads also still had water in them. So I took the heads off................
Come to find out the gaskets don't have holes to let water into the heads I called some of my nascar connections and no one can match the part number up with the gaskets I have. So now I have the right gaskets on their way. We'll be back up and running by the end of the week.
The one thing I never thought to do was, match the gasket to the head as well. I just checked it on the block.
Lesson learned, the guy I bought the gaskets from isn't sure how I ended up with that part number lol....
