Re: Caltracs Versus Triangulated system from Unlawfuls
[Re: Dos Snails]
#495009
11/28/09 07:09 PM
11/28/09 07:09 PM
Posts: 1,552 Michigan
Kiddart
yes it does make it stronger than a but weld also. good catch I have been studing this product for almost a month. it is truely a good piece to add to your rear suspension.
Thank you Kiddart
[Re: Kiddart]
#495010
11/28/09 08:07 PM
11/28/09 08:07 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
out of all these post's I don't see any thing about the Leaf Link setup IMO that is the best working low buck suspention seems to be forgoten now a days but that setup flat works and you could probably built it for under $500
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: StripeHOG]
#495013
12/01/09 09:09 AM
12/01/09 09:09 AM
Kiddart
I have heard alot about this ladder leaf!!?? what does this set up look like do you have pictures or know someone who runs it. I have heard some guys at the trac use this set up but I have never seen it in real life. Would appreciate some pics Thanks
Thank you Kiddart
[Re: Kiddart]
#495016
12/01/09 10:46 PM
12/01/09 10:46 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Try to find someone with a Bugeye Sprite (MK1 Sprite) or a Mk 1 MG Midget/MK2 Austin Healey Sprite. They have this type of rear suspension. On the Spridgets the spring is actually a QUARTER elliptic spring. It comes out from a box in the chassis and runs aft to the axle. The spring actually ends at the axle. The upper link is a bar running from the top of the axle forward to the chassis. No reason the spring cannot continue on as a half elliptic, though, like a standard leaf spring on a Mopar.
I know our MK 1 Midget handles great, have never taken it to the drag strip, though. You can see how axle windup will be well controlled.
Later Spridgets have a standard leaf spring setup; I suspect more for cost considerations than it being a better design
[Re: David_in_St_Croi]
#495017
12/02/09 01:55 AM
12/02/09 01:55 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
A leaf/link is very simple and I think was first used on the Motown Missle, Pro-Stocker, so that is how old it is. The leaf spring is attached to the housing with a pivot below the spring. Tabs are welded to the housing on either side of the spring, that extend below the spring and are bolted to a pivot that is attached to the spring with clamps. This allows the housing to pivot here, as it is not clamped directly to the spring anymore. Now upper 4-link type bars are added and the front mounts were normally placed inside the upper frame rail, right above the springs. So the leafs still hold the car up, the front segment now acts as a lower 4-link bar and the top bars have been added. They do work well, but if you were going to go to that extreme on the fabrication, why not just add coilovers, replace the front leaf segment with a bar and then you you would have a..............what, a setup EXACTLY like the Unlawful setup. If you have the skills to fabricate a leaf link, you can fabricate your own 4-bar setup like the Unlawful deal and this "bolt on" becomes a moot point.
Monte
[Re: don miller]
#495019
12/02/09 01:03 PM
12/02/09 01:03 PM
Monte_Smith
North Alabama
I certainly don't want to upstage someone with Monte's experience,but if I remember correctly the problem with a leaf/link setup aside from the spring bind in the original version, was the main leaf would distort just behind the front eye.
Exactly, thats why I said if you were going to that extreme on the fab, replace the lower segment with a bar. Some people fail to see the obvious and that is, if all this old school stuff was so great, it would still be used. It was great in its time, because there was nothing like it, now there is better stuff.......use it.
Monte
[Re: Monte_Smith]
#495020
12/02/09 07:14 PM
12/02/09 07:14 PM
Kiddart
I have almost made my decision. I am really leaning now to a ladder bar set up I did not realize how inexpensive it is, and therre are many companies that offer them. I know I need to use the 32" long ladders add the front cross bar weld a brace to my rearend then the coil over shock brace and done. then the fun part of tunning it in. I do have the skills and the place to do a ladder bar. If i can do my own roll bar, floor pans, quarter panels and rear tail light panels I can weld in a four link. Monte you are a well of knowledge thank you very much for all the info and taking time to teach us a thing or two!!! Kiddart
Thank you Kiddart
