Re: Nitrous tune up?
[Re: MegaDart]
#494766
10/12/09 08:50 AM
10/12/09 08:50 AM
Posts: 84 NC
Badfish67
NC
How much HP are you trying to spray? Why are you spraying for such a short time? You said you took out 10* of timing...was that for the whole run or only when the spray came on? You are going to need to get the bottle over 900#. I usually have mine at 1050-1100 when I leave the line.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Badfish67]
#494767
10/12/09 09:22 AM
10/12/09 09:22 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
nx says at 5 psi that would be 200hp
I am spraying for 2 secs until I am comfortable with the tuneup. I am only looking to gain .15-.2 in the 1/4mile for Rockingham in 2 weeks. I have a high 7.6x car and want to dial low 7.5x
taking out 10deg only while on the nitrous, iirc I have it ramped back in over .5sec.
[Re: MegaDart]
#494768
10/12/09 09:43 AM
10/12/09 09:43 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Wayne, call Monte 256-783-3418 you do have any time to be screwing around
Rickster
[Re: MegaDart]
#494771
10/12/09 12:33 PM
10/12/09 12:33 PM
rickstershemi
I probably will call Monte but i feel bad taking his time as I'm not a paying customer...
rt, I run 37* total timing on motor. This is a bbc headhunter 24* conventional head, 604ci 15:1 I will have to dig up the card for lobe sep, not a nitrous cam for sure
plugs looked good but I did drive it in the garage so may be misleading. I can kill it sat. after a run and check them without idling.
the 200hp tuneup calls for 5psi, I am tee'd off my belt drive that runs 6.5 to the carb so I'd think it is 6psi flowing but have not checked it. Don't really have the right tools to do so??
GET OFF YOUR POCKET
Rickster
[Re: 602heavy]
#494773
10/12/09 02:17 PM
10/12/09 02:17 PM
MegaDart
The Swamp
you must be running the older style plate which calls for 5psi FP as opposed to the later plates which use 8/10psi FP?
plate is brand new so should not be "older style" the tuneup card that came with the kit is different then the tuneups listed on their website. I think I'll give them a call
GET OFF YOUR POCKET
makes no difference, it is still empty when I stand up!
[Re: MegaDart]
#494776
10/12/09 09:19 PM
10/12/09 09:19 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
you are setting fuel pressure with the fuel pill your using in the line fixture and flowing fuel to set the regulator pressure ...? yes?
chepast
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: MegaDart]
#494777
10/13/09 01:21 AM
10/13/09 01:21 AM
Posts: 416 Eagleville Tn.
rtstreet
Eagleville Tn.
thanks heavy I talked to Mike Wood in depth today and learned a lot!! First that my alky perimeter system will not work on gas I had originally planned to spray on alky but recently saw big gains on gas and no alky fumes to kill me in the car! So looks like my alky system will end up on the dragster or on RJ. Jegs has $50 rebate on NX systems and with my racer discount a new system minus bottle for $450 is what I will do. I would've cost $300 just to convert what I have. This way I'll have some extra parts if needed.
good move, Mike is a good guy i have known him for years now, update us when new stuff arrives.
