Indy pushrods #494350
10/11/09 06:08 PM
10/11/09 06:08 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Any of you fellows ever had problems with indy pushrods breaking at the cup? broke 2 of them yesterday.
Re: Indy pushrods [Re: JACK1440] #494351
10/11/09 06:16 PM
10/11/09 06:16 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Yep.. Ask Billyjay.. Save yourself the trouble and order new.. smiths in mine now..
Re: Indy pushrods [Re: JACK1440] #494352
10/11/09 06:16 PM
10/11/09 06:16 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
Yes everyone has had problems with them, most likely over hardened. Switch to Smith Bros or Mantons and it will go away.
do a search for BillyJay's thread a month ago.
Re: Indy pushrods [Re: JACK1440] #494353
10/11/09 08:35 PM
10/11/09 08:35 PM
Michigan, US
ben1692 Offline
ben1692  Offline
Michigan, US
broke one at norwalk called trend in michigan new set much better trend sister comp to diamond pistons
Re: Indy pushrods [Re: JACK1440] #494354
10/11/09 10:08 PM
10/11/09 10:08 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I had two that had soft cups on them.The adjusters were trying to push through them.
Re: Indy pushrods [Re: super451b] #494355
10/12/09 03:26 PM
10/12/09 03:26 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
well fellows.... found yet a 3rd bad pushrod. this one the ball was pushing thru. I'm going to take your advice and put these in the trash. Thanks!
Re: Indy pushrods [Re: ben1692] #494356
10/12/09 03:46 PM
10/12/09 03:46 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Trend makes a nice product! Smith Brothers are nice also!
Re: Indy pushrods [Re: JACK1440] #494357
10/12/09 04:08 PM
10/12/09 04:08 PM
fresno ca
mikeysmopars Offline
fresno ca
I just bought the 295 ez kit, made three break in passes the weekend before the Bakersfield Pinks show. First qualifying pass it spit a push rod and of course I didn't get the two piece valley pan so we pulled the intake & head. It wore the cup clean off the top of the pushrod. I made one and made the second round of qualifying and ran a 10.50 the next round I broke again and found the exact same thing, The cup wore clean off. Called indy and was definatly not a Problem with thier kit??? I'm not a wizard at setting valves like some of the serious racers but I showed them to several builders and really dont have a good answer to it. I typically use the Mopar Performace chart to set lash. Good or Bad??
Also have been told the its because it revs too high. 470 b block stroker 7200 rpm through the lights. any feedback is appreciated.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Indy pushrods [Re: mikeysmopars] #494358
10/12/09 04:21 PM
10/12/09 04:21 PM
Indiana
79_W200 Offline
79_W200  Offline
Indiana
I had indy make a set this spring, I have ran them all season in my pulling truck. I turn 7500-ish rpm for at least 15-20 seconds each pass and have had no trouble with mine. I thought someone talked about how they are assembled or how the rod is cut causing problems
1979 W200 470
Re: Indy pushrods [Re: 79_W200] #494359
10/12/09 04:26 PM
10/12/09 04:26 PM
Colorado
506RR Offline
506RR  Offline
Colorado
Ran the Indy's in mine when I had a solid flat tappet cam. They seemed to hold up fine.
When I went with a Roller, I put in Smith Brothers Pushrods. After hearing all of the stories about the Indy Pushrods, I just didn't want to take the chance.
Re: Indy pushrods [Re: 506RR] #494360
10/12/09 04:55 PM
10/12/09 04:55 PM
They stink! Get rid of them or get ready to fish broken parts from your nice engine---SMITH BROS---all the way--
