Where can I find out about the XZZ code on a 2005 Dodge #494218
10/11/09 04:34 PM
10/11/09 04:34 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Looking at purchasing a new EGR valve for my wifes 2005 Grand Caravan. When I look up the part it has 2 choices "WITH XZZ CODE" and "EXCEPT XZZ CODE"
How do I determine what I have on this vehicle? Is there a Build sheet or data tag that I need to look for?
Re: Where can I find out about the XZZ code on a 2005 Dodge [Re: SPWC] #494219
10/11/09 05:14 PM
10/11/09 05:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Might be on the data plate which I think is on the door or piller.
Re: Where can I find out about the XZZ code on a 2005 Dodge [Re: SPWC] #494220
10/11/09 05:48 PM
10/11/09 05:48 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
the XZZ code is a sales option code.get me the last 9 digits of your VIN and i can tell you which sales code your van is equipped with
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Where can I find out about the XZZ code on a 2005 D [Re: racerAL] #494221
10/11/09 06:28 PM
10/11/09 06:28 PM
SPWC Offline OP
SPWC  Offline OP
last 9 of the VIN on the van are 05B250383
Re: Where can I find out about the XZZ code on a 2005 D [Re: SPWC] #494222
10/11/09 06:56 PM
10/11/09 06:56 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
...your van IS equipped with XZZ code..FWIW we have had nuttn but issues with aftermarket egr valves and o2 sensors..it's gotting so bad now that our techs won't use the aftermarket part...i know they offer a life time warranty but how many times do you want to change that thing before you get a good one.(or one that is calibrated correctly).? if you do decide to get 1 at your local dealer the part # is 4861662ae..it retails for around $118..to bad your so far away i could save you some $ on the part but im not sure how much $ you would have in shipping.let me know if i can help...
446 cid on E-85
best 60ft. 1.419
Re: Where can I find out about the XZZ code on a 2005 D [Re: racerAL] #494223
10/11/09 07:07 PM
10/11/09 07:07 PM
SPWC Offline OP
SPWC  Offline OP
Youve already helped with the info youve provided.Im not quite ready to replace it yet,its not in my budget this month. Next month will look better.Ill contact you and let you know . Thanks again!!
