KB Piston ring gap for 440 #493563
10/10/09 10:21 PM
10/10/09 10:21 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Need advice.
Just a street car, stock spec 440
440 bored .030
KB hypereutectic pistons
Instructions say .0065 x 4.350=.028 top ring gap
Im OK with that.
For bottom ring says follow manufacturer's instructions.
None came with the Sealed Power rings.
Original Chrysler Manual says .013-.023
Whats your recommended ring gap for the second ring?
Tricks to hand file a ring square (Low budget)?
Been all over Moparts Search and net, cant get a straight answer.
Re: KB Piston ring gap for 440 [Re: CYACOP] #493564
10/10/09 10:31 PM
10/10/09 10:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have to look up the real specs but it is about .025 to .030 on the top ring and about .018 on the second ring. But you want to follow the instructions to a T. If you did not get the specs with the rings look it up on their site. I believe I am right but not 100% sure without looking the specs up. Ron
Re: KB Piston ring gap for 440 [Re: 383man] #493565
10/10/09 10:34 PM
10/10/09 10:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I jumped the gun here but the .028 is right for the top ring. I set my second rings on my 440 at .018 and it has worked fine. Good luck , Ron
Re: KB Piston ring gap for 440 [Re: 383man] #493566
10/10/09 10:47 PM
10/10/09 10:47 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
I think thats what I will use.
Thanks Ron
Re: KB Piston ring gap for 440 [Re: CYACOP] #493567
10/11/09 01:25 AM
10/11/09 01:25 AM
put your finest file in a vise & move the ring "in" toward the tang of the file with contact in that one direction only. File one end only & keep it square & deburr it when you get the gap you want. I use .003 per inch of bore (2nd ring).EDIT each time you pull the ring out butt it together & that'll let you know if you are filing it square.
Re: KB Piston ring gap for 440 [Re: RapidRobert] #493568
10/11/09 06:28 AM
10/11/09 06:28 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
There you go
Re: KB Piston ring gap for 440 [Re: CYACOP] #493569
10/11/09 08:01 AM
10/11/09 08:01 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
FWIW I would much rather be on the too wide side than too tight on this one. End spec's with KB's for me is .0303 and I run mine at .0031/.0032.
http://kb-silvolite.com/feature.php?action=read&F_id=40
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: KB Piston ring gap for 440 [Re: MoparforLife] #493570
10/11/09 09:01 AM
10/11/09 09:01 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The KB hyperuetcics need a wide top ring gap because the ring is moved closer to the piston crown (where the heat is) and the material doesnt tranfer heat very well.
Keeping the second ring gap wide is almost always a good idea on any piston. It provides an escape path for gas pressure that can build up between the top two rings. This will help keep the top ring seated on the ring land of the piston (where it needs to be to seal well).
Take a look at some second ring gap specs on modern diesel engines.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: KB Piston ring gap for 440 [Re: Rapid340] #493571
10/11/09 09:27 AM
10/11/09 09:27 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I would gap the 2nd ring at .004/inch of bore plus .004. I think that ends up around .022-023. On the filing.. by assembling yourself you're saving a bunch. I think my ring filer cost $30. IMO, it's not worth doing without the proper tools. Thye are that important to good power production.
