Slant 6 timing #492882
10/10/09 09:30 AM
10/10/09 09:30 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
What should the overall total advance timing on a slant 6 be? I am at about 32 total and that just seems a little shy. The distributor has about the right mechanical advance in it at 20 degrees, but if initial timing is at 10 or 12 degrees, well that leaves me with 30-32 total. This isn't close to what you'd run a V-8 at. Is this right? Is there advantage to changing this? If you have some info I would surely appreciate it. Thanks
Re: Slant 6 timing [Re: SportF] #492883
10/10/09 10:18 AM
10/10/09 10:18 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
30-32 is about right. Slants don't usually like a whole lot of total timing. On the street your vacuum advance will make up for it anyway.
I run about 27 total on my race junk, and 18-20 when spraying.
Re: Slant 6 timing [Re: slantzilla] #492884
10/10/09 10:29 AM
10/10/09 10:29 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Thanks I appreciate the info. Since I run about 36-38 on my race car I was a little taken aback by the 32. I will leave it as is.
