Re: what causes this?
[Re: mopar dave]
#491779
10/08/09 04:31 PM
10/08/09 04:31 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Is that street tires ? What supsension ? looks like its pushing to torque to passenger side stiffen the spring or shock on passenger side . don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: mopar dave]
#491781
10/08/09 04:43 PM
10/08/09 04:43 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
The car before you had a spinning problem, if I'm hearing right, so maybe it was something on the track or lack of track preparasion (SP?) Does it do it (jerk to the right side)all the time? if so then it is something in the cars drive train and not the track
[Re: mopar dave]
#491785
10/11/09 12:45 PM
10/11/09 12:45 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Looks to me like driver rear is a little higher in the back then the passenger rear. Not sure of what suspension you have but you could try some preload in the passenger rear. If you got the car on scales it might show that you are light on the passenger rear. Watching the car in the water box it looked to me like it was going to pull right on the hit. Nice car by the way.
76 Duster
work in progress
