Exhaust drone (Magnum) #490531
10/07/09 09:25 AM
10/07/09 09:25 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Picked up a Magnum R/T yesterday..nice car. It has a Borla exhaust system. Thing is it has a terrible drone at 40 and when the cylinders drop off (I'll have to get used to that) Anybody run aftermarket mufflers on theirs? and if so what do you guys like? I might see about Dynomax's???
Coming soon!!!!
Re: Exhaust drone (Magnum) [Re: Mr.Yuck] #490532
10/07/09 12:22 PM
10/07/09 12:22 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Re: Exhaust drone (Magnum) [Re: Mr.Yuck] #490533
10/07/09 01:33 PM
10/07/09 01:33 PM
San Francisco Bay Area
MrAngry Offline
MrAngry  Offline
I have a JBA system on mine and suffer from the same drone problem... my solution... I'm back to stock.
Question though - are you running resonators?
Never trust a pretty girl... or a lonely midget.
Re: Exhaust drone (Magnum) [Re: Mr.Yuck] #490534
10/07/09 02:17 PM
10/07/09 02:17 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
Check to see if your system has any resonators on it.I had 40 flows and no resos,3"x 16" rolled tips on my 08 charger R/T, TONS of drone . Added Blastin bobs 2&1/2" glasspack resos and 4" DW tips.Now its wifeand long drive friendly,sounds good at idle/startup & BA at WOT.D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: Exhaust drone (Magnum) [Re: bigD] #490535
10/07/09 03:47 PM
10/07/09 03:47 PM
Detroit, MI.
Mancini Racing Offline
Detroit, MI.
We have a Corsa system on our 2008 Charger Daytona development vehicle.
It's drone free even with long-tube headers.
With the 5.7L HEMIs and MDS, you have to be careful on the type of cat-back exhaust you put on these cars.
The other alterantive is eliminate the MDS with a a Diablo Predator hand-held tuner but your MPGs may suffer.
Re: Exhaust drone (Magnum) [Re: Mancini Racing] #490536
10/07/09 03:51 PM
10/07/09 03:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How big and what kind of tips does it have?
Re: Exhaust drone (Magnum) [Re: stumpy] #490537
10/08/09 07:08 AM
10/08/09 07:08 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
not sure looks at least 2.5 maybe 3" w/ the big borla tips...they seem to be baffled.
Re: Exhaust drone (Magnum) [Re: Mancini Racing] #490538
10/08/09 07:10 AM
10/08/09 07:10 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
The system is designed for the car, so I'm guessing it's ok. I do plan on buying the tuner. It has settings from econ to performance.
Re: Exhaust drone (Magnum) [Re: MrAngry] #490539
10/08/09 07:11 AM
10/08/09 07:11 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Is there room? the mufflers are at the tail end of the car. The Borla tips look like they could be baffled. I'm not looking at replacing the entire system. I was thinking of just a muffler swap.
Re: Exhaust drone (Magnum) [Re: Mr.Yuck] #490540
10/08/09 09:17 AM
10/08/09 09:17 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Are there any lengths of exhaust pipes that are 55 to 75 inches long?
If so, put a resonator in the middle.
If for some reason you can't use a resonator
it is also possible to kill a drone noise with a T-stub,
which is a dead end length of pipe off a T junction
Someone in the family
or your group of friends
good at math?
Have them read:
http://www.audioholics.com/education/acoustics-principles/helmholtz-resonant-absorber
if you look at the intake of the new Ford 6.2 V8 you will see T-stubs in use
Re: Exhaust drone (Magnum) [Re: Mr.Yuck] #490541
10/08/09 02:14 PM
10/08/09 02:14 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
Does your system have a pair of mufflers(or suitcase muffler) ahead of the rear axle assmembly as well as mufflers(resonators)at the rear? The previous owner could have deleted the center muffs to get a more agressive exhaust tone. Also,the preditor can shut off the mds ,but you will still have drone at certain speeds/rpms. D,
Re: Exhaust drone (Magnum) [Re: bigD] #490542
10/08/09 02:30 PM
10/08/09 02:30 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yeah I think it has all 4. I thought the mufflers were aft but those are resonators. Jeesh 4 mufflers and still a drone.
Coming soon!!!!
