Re: 600+ HP 440 SB Mopar on pump gas.....
[Re: BradH]
#490349
10/08/09 02:44 PM
10/08/09 02:44 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Maybe I missed it... can you give any details on the different carbs you tested?
Customers QF 950 annular carb vs. my OOTB 1000HP.
[Re: Brian Hafliger]
#490350
10/08/09 03:09 PM
10/08/09 03:09 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
with the 6K RPM ceiling imposed by the owner, is there much advantage to a solid cam over a fast rate hydraulic? in some of andyF's articles on his old 470, IIRC, a comp juice cam kept up with a solid pretty good until ~6000 RPM, and that's where the juice cam peaked, while the solid kept going up.
especially if it is destined for a street car, could a hydraulic roller cam have made the same amount of power with less questions of durability given the state of modern oils?
just a thought....
[Re: patrick]
#490352
10/08/09 07:30 PM
10/08/09 07:30 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
just a thought....
After the first cam went flat, the customer and I talked about seveal different ways to go...however he already had the Schubeck lifters and after close inspection with a mag.glass we decided to go back to a FT cam. I could have gotten Comp to build a set of hyd. roller lifters for the 48° block, but after discussing it with Billy Godbold and Chris plus my own experience I felt that with the 1.65 ratio rockers that the best way to go was the FT cam.
Now I might have been wrong about that, but I've seen hyd rollers give up some steam near 6000rpm, and I didn't want to go through that...mostly because the customer had already spent so much and time was wearing down on this project.
We did discuss going solid roller, with my lifters I felt it would last quite a while, but in the end cost was a bit high and I think the customer was tired of the hassle and $$$ spent. If he hadn't had the Schubeck's I think we would have went with a streetable roller grind which is what I really wanted to do. I wanted 650HP from the start of this project, but limited my dreams to 620's with the FT cam. I think we would have been there with the first cam.
I will have pics up this weekend I hope, maybe sooner. Not anything much different than what I've posted before, but at least they are fun to look at...LOL!!
Brian Hafliger
#490365
10/12/09 01:03 AM
10/12/09 01:03 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Close!
I've often wondered, the indy heads don't clear pushrods on a 59 degree solid roller or a 59 degree hydraulic roller and apparently they are really tight on a 48 degree flat tappet too?? What exactly do they have those pushrod areas clearanced for???
