Re: changing rocker ratios
[Re: ahy]
#490119
10/06/09 10:57 PM
10/06/09 10:57 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
ok, but for example... has been told since I have memories here and several Mopar boards that old MP Cam grinds are right OLD DESIGN because the low lift profile and long duration times. Nowdays performance is just right the opposite.
so if you have an HP Resto cam you can increase performance keeping low duration and 115 centerline, so LOT OF DRIVEABILITY... or not ?
yes I know you can pick another cam, but still.
[Re: ahy]
#490121
10/06/09 11:39 PM
10/06/09 11:39 PM
NachoRT74
Valencia, España
do you think jump 450 stock cam lift to 480 lift really needs clearence check? if so, then nobody could install a modern grind cam , or even a stock MP 509 camshaft then if changing also the camshaft to a modern cam grind DEFINITELLY will need to be checked anyway is true, check everything is a good advice, but some cases I don't think DEMANDS a check
[Re: NachoRT74]
#490122
10/06/09 11:50 PM
10/06/09 11:50 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
It isn't valve to piston clearance thats an issue... It is pushrod to cylinder head & block that can be a problem... To change the ratio the effective leverage (ratio) is changed.. Your not changing the distance of the valve stem to the center of the rocker fulcrum so therefore you must be changing the distance from the center of the rocker fulcrum to the pushrod.. To increase the valve lift you need to shorten the distance from the center of the rocker fulcrum to the pushrod... So that potentially brings the pushrod into contact with the block or head...
