How much I win with 1.6 againts 1.5 rockers ratio
#489734
10/06/09 01:19 PM
10/06/09 01:19 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
what you read. I dunno how to calculate that.
IN FACT, WHATS THE ROCKER RATIO ? lol... where is that spec located on rocker geometry
Re: How much I win with 1.6 againts 1.5 rockers ratio
[Re: Mr.Yuck]
#489737
10/06/09 01:37 PM
10/06/09 01:37 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Or you can take your cam say 509/1.5=339.3 and multi by 1.6=542.9
I forgot to show the first step!
[Re: 68CoronetRT]
#489739
10/06/09 02:13 PM
10/06/09 02:13 PM
NachoRT74
Valencia, España
so, then...
Stock Hp Mopar resto camshaft with .450/.458 will convert in to:
.450/1.5=.300x1.6=.480 .458/1.5=.3053x1.6=.48853
new resto cam will be: 268/284 dur with .480/.48853 lift
and the 474 MP cam
.474/1.5=316x1.6=.5056
new 474 cam will be: 280 dur with .5056 lift
[Re: 68CoronetRT]
#489740
10/06/09 02:18 PM
10/06/09 02:18 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
. . . IN FACT, WHATS THE ROCKER RATIO ? lol... where is that spec located on rocker geometry
A stock 440 rocker has a 1.5 ratio. What that means is the rocker arm opens the valve 1.5 times more than the actual lift of the cam lobe. In the examples above a cam that has a lobe .334" high will open the valve .334 x 1.5 (rocker ratio) for a total of .501" That same cam using a 1.6 ratio would open the valve .334 x 1.6 (rocker ratio) for a total of .5344"
NOTE: Caution should be used when changing cams and rocker ratios because without pulling the heads and checking for clearance you may cause the valves to extend so far the piston smashes into them.
No need to pull heads to measue valve to head clearance. Very easy to do with heads in place.
[Re: MoparforLife]
#489741
10/06/09 02:21 PM
10/06/09 02:21 PM
NachoRT74
Valencia, España
where in rocker is that difference ? I mean physically.
I got a nice deal trying to get adjustable valve train to use with round end pushrods but now I'm unsure if get 1.5 or 1.6 ratio rockers ( 1.7 will be too much ). I'm planing to use 474 cam, but I have a resto cam as a backup.
[Re: NachoRT74]
#489742
10/06/09 02:32 PM
10/06/09 02:32 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
your lift calculations are correct. 1.6 ratio rockers have the pushrod tip slightly closer to the pivot. you may have to clearance the pushrod holes for your pushrods because of this.
[Re: patrick]
#489743
10/06/09 02:42 PM
10/06/09 02:42 PM
NachoRT74
Valencia, España
More stuff to check !! I think have enough with what I already have... I think I'll keep with stock ratio then. Is enough trying to get this valvetrain to be able to mill down heads without headaches about pushrod lenghts. ( already have rocker shims if I need to correct rocker/valve geometry after the mill down job ) being in USA wouldn't be a problem, but outside USA and being my driver I don't want to comfront more problems trying to get some change and park my car waiting for more parts. even there is LOT OF TEMPTATION on use a resto cam with those new lift values using 1.6 rockers and resto 115 centerline, being a driver car. although, still thinking will .505 be to much lift on a 400 engine if I get... lets say 10:1 CR ( milling heads OR if KB240 pistons gets zero deck ? ) Does that lift value needs some job on heads at valve guides or wherever at head ?
[Re: NachoRT74]
#489744
10/06/09 03:08 PM
10/06/09 03:08 PM
patrick
Grand Haven, MI
duration is a bigger influence on drivability and low RPM performance, not lift. lift is an indicator of potential power if head flow can support it.
[Re: MoparforLife]
#489746
10/06/09 03:28 PM
10/06/09 03:28 PM
NachoRT74
Valencia, España
I have around 120 lbs at stock installed height hughes springs... can't recall the PN... I think they are 1016... got them used on Carlisle last year
rest of setup
-Magnum 400 engine standart bore sleeved ( 25K miles on it, so will be just honed ) -KB240 pistons -850cfm stock TQ carb -MP 280/474 camshaft ( resto HiPo cam as back up ) -166K TC ( 175K TC to arrive someday as backup ) -basic 2186 eddy intake -452 heads ported and milled ( dunno how much yet, will be defined when pistons are measured in the holes ) -stock HiPo exhauts manifolds -exhaust pipes already upgraded to 2.5" -Summit double timming chain setup -3.55 SG axle -27" wheels -Lunati 75713 retainers -Stock valves -Metallic headgasket -stock pushrods
[Re: MoparforLife]
#489748
10/06/09 10:32 PM
10/06/09 10:32 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
No need to pull heads to measure valve to head clearance. Very easy to do with heads in place.
Here's my guess: Cylinder TDC, install weak spring, set depth gauge to top of valve stem and then measure total distance to contact on piston. Subtract known lift?
[Re: 68CoronetRT]
#489749
10/07/09 12:08 AM
10/07/09 12:08 AM
MoparforLife
Upper Midwest
Starting a few degrees before and ending few degrees after TDC. Valve to piston clearance is not the closest at TDC but usually a few degrees after.
[Re: NachoRT74]
#489751
10/07/09 02:25 AM
10/07/09 02:25 AM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
so, then...
and the 474 MP cam
The quick method for converting 1.5 ratio lift to 1.6 ratio lift is to multiply the 1.5 ratio lift X 1.067.
[Re: Reggie]
#489752
10/07/09 09:59 AM
10/07/09 09:59 AM
NachoRT74
Valencia, España
well yes I guess, same than changing to 1.7 the multiply factor will be 1.1333
but I wanted better to know where it was exactly the difference.
[Re: MoparforLife]
#489753
10/07/09 07:19 PM
10/07/09 07:19 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Correct me if I'm wrong here, but isn't the exhaust valve-to-piston closest just before TDC, and the intake closest just after TDC?
-Charles
