A-Body Rallye Dash Lights Not Working?? #487639
10/04/09 02:45 AM
10/04/09 02:45 AM
Colorado
CuriousYella70 Offline OP
Colorado
Over the summer my rallye dash gauges and lights in the Duster stopped working. I just yanked the cluster and figured out the gauges for the most part but still cannot figure out why the lights are not working anymore. Lights are not blown and all fuses in the fuse box are good to go, what am I missing here? I did notice that one of the lights that's located near the bottom of the tach area is missing in action, would a missing light cause them all to stop working? Right now I have just one light that lights up.
Re: A-Body Rallye Dash Lights Not Working?? [Re: CuriousYella70] #487640
10/04/09 12:10 PM
10/04/09 12:10 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Just follow the circuit board with continuty setting on a voltmeter or power it up and use test light.
The pins get loose/broke on those. But if it all worked last time you drove it, maybe some sore of common ground get messed up.
Clean the contact areas too.
Re: A-Body Rallye Dash Lights Not Working?? [Re: CuriousYella70] #487641
10/04/09 01:52 PM
10/04/09 01:52 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Did you replace your dimmer switch yet?
Re: A-Body Rallye Dash Lights Not Working?? [Re: Steve340] #487642
10/04/09 11:33 PM
10/04/09 11:33 PM
Colorado
Colorado
Dimmer switch didn't need to be replaced....all of my switches work great.
