Fed need more speed!/Help me sort out combo! #486998
10/03/09 04:07 PM
10/03/09 04:07 PM
Stockholm,SWEDEN
The Nutcracker Offline OP
Stockholm,SWEDEN
I think the 1/4 MPH is low, the car ran on the RPM limiter a long way 7000 RPM Could it be a converter problem?
Frontenginedragster built in 1962
Cr-mo chassi 195”wheelbase
Wheight 1688 LBS/766KG with driver
Rear: 8 ¾ rear 4.10 spool
Tires:33/10.5 MT slicks 6 PSI tire pressure
Trans: TCI Long Glide Transbreak
Converter: TCI Super Street Fighter 3000 stall
Engine: Mopar 440 stroked to 498
Engine made 722HP/5800RPM 727LBF/4700RPM
4:15 stroke Stage VI heads M1 intake
1050 Dominator
Crower solid roller 319”/324”.670/.643
lobe sep 110
1/8 5.34/129.8 MPH
1/4 8.45/154.6 MP
Best 60 foot# 1.1896
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #486999
10/03/09 04:37 PM
10/03/09 04:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why are you running a street fighter converter? thats the first area I would look at
Re: Fed need more speed!/Help me sort out combo! [Re: Quicktree] #487000
10/03/09 04:48 PM
10/03/09 04:48 PM
Stockholm,SWEDEN
Stockholm,SWEDEN
It was in the car when i bought it from USA, there where a stock 440 in it that blow up on its 5 run. Replaced it with the 498.
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487001
10/03/09 05:52 PM
10/03/09 05:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would put the rev limiter up to 7600 they start to limit 300 rpm early 6700 rpm is only 149.00 mph with 7 % converter slip.
Re: Fed need more speed!/Help me sort out combo! [Re: Dodgem] #487002
10/03/09 06:02 PM
10/03/09 06:02 PM
Stockholm,SWEDEN
Stockholm,SWEDEN
Engin made most horsepower at 5800RPM, i would rather not rew it to high.
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487003
10/03/09 06:10 PM
10/03/09 06:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what was the 60'
Re: Fed need more speed!/Help me sort out combo! [Re: Quicktree] #487004
10/03/09 06:24 PM
10/03/09 06:24 PM
Stockholm,SWEDEN
Stockholm,SWEDEN
best 60 foot# 1.1896
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487005
10/03/09 06:31 PM
10/03/09 06:31 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
imho running it on the limiter is probably worse than letting it turn past 7k. i understand you not wanting to turn it fast but banging on the crank with the limiter isn't a good idea either. peak HP at 5800 sounds a little slow i would think it would peak higher. i know you've had problems with wheelstands on launch did you get that sorted? if i recall correctly my car goes through around 7300 160ish MPH. that's with a 4.10 axle, 8" ATI Treemaster and 14x32 goodyears. i figure the engine is making around 600HP. if that engine is making over 700HP your numbers are off. as mentioned the first thing i would do is get a good converter in the car. i would expect my tires to grow more than yours but given the >700HP you should be running over 160MPH. if the engine does in fact peak that low and you want to turn it slower you may end up having to change the axle ratio.
Re: Fed need more speed!/Help me sort out combo! [Re: jamesc] #487006
10/03/09 06:51 PM
10/03/09 06:51 PM
Stockholm,SWEDEN
Stockholm,SWEDEN
The engined has been on the dyno could be a little less HP because the distributor isnt looked out, had to lower the ignition.
The wheelstand problem is solved ,im more used to it and adjusting the wheeliebars. The motor is more of a boatengine than a raceengine, unported VI heads making a lot of torque. I think that the converter may be the problem. do you now a good sourse for a PG vert. For a carpenters budget!
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487007
10/03/09 06:53 PM
10/03/09 06:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
don't know about there but you should be able to pick up a decent pg converter pretty cheap used.
Re: Fed need more speed!/Help me sort out combo! [Re: jamesc] #487008
10/03/09 06:58 PM
10/03/09 06:58 PM
Stockholm,SWEDEN
Stockholm,SWEDEN
On the run making 1/8 5.34/129.8MPH
1/4 8.45/154.6 MPH I was shifting at 7600RPM and had the rewlimiter at 7800RPM.
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487009
10/03/09 06:58 PM
10/03/09 06:58 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I went that fast with a 550+ hp 440 and a Coan 3800 convertor, 3.91 in a 1900 lb FED. I was using 6800-7300 rpm to do it. I think it's the limiter holding you back. You seem to be hooking up. More converter means you would have to rev higher. Does it feel like it's pulling all the way? I think that you could use less gear and be more successful, perhaps a 3.5 gear. I know that I was a little over geared and should have used a 3.5.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Fed need more speed!/Help me sort out combo! [Re: racealittle] #487010
10/03/09 07:05 PM
10/03/09 07:05 PM
Stockholm,SWEDEN
Stockholm,SWEDEN
It pulls hard first. Could the converter be slipping?
1/8 5.34/129.8MPH
1/4 8.45/154.6 MPH
Does the difference between 1/8 and 1/4 look ok?
With the torque could I do better with another gear?727LBF/4700RPM The engine feel very strong.
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487011
10/03/09 07:20 PM
10/03/09 07:20 PM
Stockholm,SWEDEN
Stockholm,SWEDEN
Im of for bed! Back in the morning!
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487012
10/03/09 07:21 PM
10/03/09 07:21 PM
racealittle Offline
racealittle  Offline
I talked with Larry Sheppard back in the early '90's about gear choice for a FED. He told me 3.5 was the optimium gear choice for the kind of motor I was running. I told him I had a 3.9 and a 4.10 with no money to try anything else at the moment. Told me to use the 3.9, but the 3.5 gear would be the answer.
You have a larger motor that makes more torque and hp earlier. So I think with 32 or 33" tires a 3.5 gear would be like the 3.9 gear I was using. It got the job done, but I was not effectively geared for the last 100 feet or so. I don't think the converter is the problem. The car is light and hooks. More convertor would get you near a 1 second 60 foot or better. I never got to try my 730 hp 440 and 5600 convertor in the digger. I sold the car last April after 20 years.
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487013
10/03/09 07:30 PM
10/03/09 07:30 PM
Stockholm,SWEDEN
Stockholm,SWEDEN
Could the zoomieheaders hold me back? I do have a pair of alteredheaders. The engine was dynoed using regular dynoheaders.
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487014
10/03/09 07:49 PM
10/03/09 07:49 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I think what everyone is telling you is if you want the motor to be at a lower rev at the finish line, you have to change to a lower (number) gear or a taller tire. Given that 14X32 is pretty common and big, the best answer would be to change the rear gear. The converter may be slipping, and replacing it with one more suited to your combo may help in the 1/8th, but you are running out of car before you are at the end of the 1/4.
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487015
10/03/09 07:52 PM
10/03/09 07:52 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The first question on my mind was the Zoomies and whether they were on the dyno. Ditch them for a good set of 4 into1's and you'll get results. I also agree that you'll be better off with a gear close to 3.5 ratio. Your combo is way off the HP/weight you stated. Converter isn't ideal but somethings killing that combo.
Re: Fed need more speed!/Help me sort out combo! [Re: goldmember] #487016
10/03/09 07:53 PM
10/03/09 07:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Fed need more speed!/Help me sort out combo! [Re: The Nutcracker] #487017
10/03/09 08:17 PM
10/03/09 08:17 PM
jamesc Offline
jamesc  Offline
the zoomies aren't the best for HP that's for sure but your numbers are way off. i wouldn't be using the zoomies either way but be careful about changing too many things at the same time you can get even more lost. assuming the engine is making close to the HP you say it dynoed at the zoomies shouldn't slow it to the point you're at. with no converter slip or tire growth 7000 rpm with a 4.1 and 33" tires should be running close to 168mph. if you're car is turning 7000 rpm and only running 155mph that converter looks to be slipping a ton. no way i'd put a 3.5 gear in it, 3.9 is as far as i would go but you've got something else going on other than axle ratio. can you borrow a decent 8" race converter off someone? when running a power glide the converter is VERY important. without actually seeing the car run in person it can be hard to give good advice but no way that engine should be turning 7000 and only running 155. here's a link to a ratio/rpm/speed calculator. this is strictly numbers with no accounting for tire growth or converter slip. http://www.markwilliams.com/calculators.aspx here's one for converter slip http://www.wallaceracing.com/converter-slip.php
