Aluminum drive shaft #486777
10/03/09 10:45 AM
10/03/09 10:45 AM
Australia
moparmc Offline OP
moparmc  Offline OP
Australia
Can a 3.5" .125 wall aluminum drive shaft survive 800+ hp and 3400 lbs or should I look at other options? Also has a t/brake.
Re: Aluminum drive shaft [Re: moparmc] #486778
10/03/09 11:09 AM
10/03/09 11:09 AM
Q
Quicktree Offline
Quicktree  Offline
Q
my dynotech 3.5, they said was good to 1000hp and many have exceeded that. not sure on the wall thickness though.
Re: Aluminum drive shaft [Re: moparmc] #486779
10/03/09 05:48 PM
10/03/09 05:48 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i have a aluminum drive shaft,in a 3800# charger with a four speed.the motor dynoed 850 hp,and i beat the hell out of it,no problems so far.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Aluminum drive shaft [Re: Old School] #486780
10/03/09 06:29 PM
10/03/09 06:29 PM
i got a MWilliams aluminum 3.5" driveshaft in my 65 plymouth making 835 hp.no problems, just use 1350 U joints on both ends.
