Never Knew, old Urethane Bushings, Self-Destruct
#486360
10/02/09 05:42 PM
10/02/09 05:42 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Working underneath my Jeep, I leaned against a shock-absorber and it moved laterally.
When I looked up, the Eye Bushing was completely gone, none of it was remaining, just the bare bolt.
The shock was still Ok, so I bought replacement eye bushings.
I never knew when they failed, that they basically crumble. The remaining bushings were cracked and dropped out easily in pieces as well.
Not a comforting thought. I am replacing all the shock bushings now.
Re: Never Knew, old Urethane Bushings, Self-Destruct
[Re: jcc]
#486363
10/03/09 01:13 PM
10/03/09 01:13 PM
D_C
Yes, it was a surprise to me. Of course, standard rubber bushings also deteriorate, but usually not all at once like the urethane did.
Now I'm wondering about the Urethane Motor, Transmission mounts and particularly the Lower-Control Arm Bushings on my Charger.
[Re: SomeCarGuy]
#486369
10/03/09 10:08 PM
10/03/09 10:08 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I get how the UV damages the parts, but how does a LCA bushing get much light on it?
It's not just the light, it's just that UV is the hardest on it.
[Re: ScottSmith_Harms]
#486370
10/03/09 11:28 PM
10/03/09 11:28 PM
Posts: 22,697 Bitopia
jcc
Bitopia
Maybe we have stumbled on a giant undercover urethane conspiracy .
In my case I could never pinpoint a cause for urethane caster failures, some wheels were never in daylight, nor wet, some just sitting on shelf never even being rolled, some not bothered were near welder, with stray UV and Ozone exposure, oddest thing to me was how they all died at same time, kinda like how fire ants all bite at the same time.
[Re: 440gtx6]
#486372
10/04/09 02:21 AM
10/04/09 02:21 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Every environment is different so unless you do a lab test on your particular parts the reason the failed is just a gigantic guessing game. Being from the plastics industry (20+ years) and being VERY familiar with Urethanes as the company I worked for made all of the Urethane ski goggles for both Scott & Smith Goggle (my name is just a coincidence ) I can tell from personal experience having been involved with countless lab tests, that UV is the biggest enemy of Urethane, ozone, etc. are also problematic.
