Re: what grade of oil do you suggest?
[Re: rebel]
#485839
10/02/09 02:02 AM
10/02/09 02:02 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
I like and use Valvoline 5W20Wt or 5W30 if I can't get the 5W20 One of the reasons is the results of dyno testing thin oil versus standard 30W, I saw a HP gain or loss on the 30W with oil temps. No change on power on the 5W20 or the 5W30 as long as the oil temps are at or above 130F on the 5W30 and no change on the 5W20 no matter what the oil; temps where(all test where done with the outside air temps at or above 70F in the Mojave desert ) This is on all the motors I build and race except when the power gets above 750 HP then it is time for Pennzoil 25W50WT racing oil
[Re: Cab_Burge]
#485840
10/02/09 03:44 AM
10/02/09 03:44 AM
Triple Threat
Renton Washington
I run 20w50 Brad Penn in my car. Its a bracket car, so if I give up a couple horsepower with the thicker oil I'm not too concerned, I'd rather have the motor live a longer healthier life.
[Re: Triple Threat]
#485843
10/03/09 12:01 AM
10/03/09 12:01 AM
Cab_Burge
My motor has 4 yrs. of pounding on it , during the spring,summer and some fall weather depending when it snows here Plus two different dyno sessions with around 35 pulls each session. I have driven and raced it enough, shifting at or above 7000 rpm , to have two Mopar brand solid roller lifters break the wheels in half. The rod and main bearings look absolutely perfect, the thin oil circulates quicker and my oil temps never exceed 200 F even in slow traffic in the summer Most street motors don't begin to strain most regular motor oils, unless you tune it bad enough to cause the motor to detonate, all bets are off when you make the motor detonate or ping Remember the two main reasons we use motor oil in our motors is to lubricate and cool, there is no magic in thicker oils
[Re: Cab_Burge]
#485844
10/03/09 01:33 AM
10/03/09 01:33 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
I also prefer a thinner oil (30wt.) to a thicker oil (50w.) no matter what. If high temps are the norm, then go synthetic and use a quality oil. We are just now changing over to Torco oil and I hope to have some data soon on how if performs compared to other oils on the dyno. I would never run a light oil (0w. or 5w.) for HP gains in any of my engines....if you need more HP there are better ways of getting it!
Brian Hafliger
[Re: rebel]
#485845
10/03/09 11:11 AM
10/03/09 11:11 AM
Posts: 16,925 NC
440Jim
NC
Years ago I used to run 20W-50. Then I went to 15W-40. Now I run 10W-30 in my drag race engine. I recommend running a good quality race oil and changing it every 50 passes or 3-4 months; as long as you are not seeing any oil contamination. I use Brad Penn racing 10W-30. If you are running Indy Heads (SR, 440-1) I recommend restricting the oil feed lines to the heads.
[Re: 440Jim]
#485848
10/04/09 12:03 AM
10/04/09 12:03 AM
Posts: 325 Greenville, WI
Big B
Greenville, WI
What weight oil you use depends largely on oil temp and bearing clearance. A 2owt would work fine up to about 180 30wt up to 200 50wt over 200 A 50wt at 215 degrees has the same viscosity as a 30wt at 180 degrees. I run my car on the street and see 220+ oil temps all the time. If I ran a 5w20 I would have no oil psi. A drag car that never gets above 160 could use a 5w20 no problem.
[Re: Big B]
#485849
10/04/09 12:12 AM
10/04/09 12:12 AM
Cab_Burge
My Duster motor has really loose bearing clearances(.0035+ ) and Harland Sharp roller rockers with full time oiling and no restrictors, it has 17 to 19 lbs at 850 RPM at 200 F oil temps with 5W20 WT It does have thirty lbs. at 1200 rpm at 200 F and 65 lbs at 7000 RPM
[Re: Big B]
#485851
10/04/09 12:42 AM
10/04/09 12:42 AM
Cab_Burge
Interesting. You must have one hell of an oil pump. I have a set up very close to yours. I also have the pressure fed Isky Red Zone lifters. I think those suck oil psi down too.
My oil pump is either a Mellings high volume or the other make, I can't remember which I did trim the oil bypass spring to lower the pressure when it was on the dyno the first time, it was making peak power at 5600 RPM so I trimmed it to have 65 lbs at 6000 RPM with 5W20 at 160 F After I started racing and testing it at the track I found out that the car would run the fastest when shifted above 7000 RPM I used a set of the new Mopar brand solid roller when I first built it, I have broken two of them since then It now has a set of the early Engle blown alcholol lifters in it I have not ran that motor since replacing the lifters and having the cam repaired this last time, maybe it will get back into the car this winter, maybe not
[Re: Brian Hafliger]
#485853
10/04/09 06:56 AM
10/04/09 06:56 AM
Posts: 257 madison, ohio
modified1090
madison, ohio
Not if you have to hot lap the last few rounds....
what about the zinc levels dropping in the oil? i run a flat tappet cam and have heard that the lower zinc in conventional oils can destroy this type of cam. i have been on the lookout for an oil that has the higher zinc at a reasonable price. i just can't see spending $10 a quart for an oil that i am going to change after a month of running. recently i bought a couple of gallons of lucas 15w-40 long drain truck oil.
[Re: modified1090]
#485856
10/04/09 01:48 PM
10/04/09 01:48 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Not saying you guys don't know your stuff, but call Joe Gibbs. http://www.joegibbsracingoil.com/They've spent many many dollars on oils and finding out what works best with different clearances, ring packages, etc... They know their stuff, I got to sit through one of their seminars and I was impressed with the knowledge they had.
[Re: dodgeboy11]
#485857
10/04/09 02:00 PM
10/04/09 02:00 PM
Big B
Greenville, WI
Joe Gibbs makes excellent oil, but has less detergents. Brad Penn is just as good, is much cheaper, and has a lot more detergents. My engine builder has used both, and said they are about the same quality wise. That's why he recommends Brad Penn. I use their 20w50 in summer, and now their 15w40 in spring and fall.
